#16
Re: What's going in your Withholding Allowance?
The belt that is on there cannot get any tighter, it was tensioned into place using a clamp and does not appear to flex at all if you push on it. It is not one of the kit belts it is one with a much shallower tooth profile that we got for free from a mentor's work. We are looking at replacing it with some of the kit 5mm belts after we find some local teams not using the parts we need and we calculate what belt length we need to purchase.
#17
Our robot was built to take advantage of the withholding allowance from the beginning. The drive modules detach, as a unit, from each side of the frame, and the control module is completely detachable, too.
Now we just need to build a dummy chassis to mount the modules on to and we've got five weeks of traction control and driving practice before Seattle. (And, yeah... we could sure use it!) Jason |
#18
We're keeping our control system, part of the turret, and we are bringing in our redesigned rollers.
#19
ARGGGG! You always beat me to posting
#20
We would love to keep the cRIO at home for these crucial few weeks, but decided against it because of the dangers of plugging everything in wrong.Plus, "obtain" sounds slightly illegal.. I like it.. --Jordan |
#22
Even properly tensioned belts can slip if they are not being used in the correct situation.
#23
Maybe its just tiredness setting in... but I was rereading all of the Withholding allowance rules, and being that it is 40lbs of FABRICATED items, this means things like anything in the electronics system (other than fabricated wires), ie speed controllers, camera (w/out mount), cRio, wireless bridge, etc dont count... Am I reading that right? I couldnt find anything in the Q&A or rules to contradict that. (Although I think my electrical team would think it insane to unplug any of the board other than the basic controls to keep!).
We are only keeping the control system basics, likely the camera, our lexan panels to add stickers, and we are going to do some upgrades to our conveyor system. |
#24
-dave . |
#25
We're witholding bumpers, one piece of material from our hopper, & some side panels just so we can get our sponsors & team number on them before the competitions.
All these things together are way under 40 lbs, so we're good to go. ![]() |
#26
http://forums.usfirst.org/showthread.php?t=11913 http://forums.usfirst.org/showthread.php?t=11854 Of course, since the crates are pretty much sealed by now, this might come a little bit late, but it should be pretty easy to have items such as the Jaguars (so long as they still contain their magic smoke) and cRio count as COTS. Gears and motors, perhaps, a little less so. Jason |
#27
First, consider this Q&A response. For the sake of avoiding word-mincing, note that this question is clearly about "strip[ping] the robot of many expensive but easily installed COTS items before shipment" and "bring[ing] all those COTS items under R35". The answer indicates that wheels removed from a robot are considered COTS, a disassembled cRIO is considered COTS, and a Toughbox assembled per the directions is considered to be COTS. Now consider this more recent Q&A response. I certainly wouldn't consider any part that has been previously installed on a robot to be "brand new", particularly not something that is obviously in a different form factor than typically presented by the vendor (in the case of the Toughbox example). I'd like to call myself "reasonably astute", as required by the second link, but I can't reconcile these responses for the life of me. Help? |
#28
Jason,
Thanks for those Q&A, I had been dilligently hunting the Q&A until the last week, and in looking through the Q&A I figured it would be in Section 8 Fabrication Schedule (since thats what seems to deal with the fabrication period after ship). But it still seems fuzzy: Quote:
I guess I thought this 40lbs was simple until I really read/reread it and saw those Q&A posts... I guess at any rate, our cRio weighs 3.12lbs, and the lexan I held back weighs about 2.5lbs, so we have 36.38lbs to go if all signs are pointing at the cRio being included. And Joey, I totally agree... the wheels are definitely not good enough for a vendor to resell after a team has used them, and if the disassembled wheels, bearings, etc are COTS, then why wouldnt the cRio be? I posted questions about the cRio in the Q&A, hopefully we get a speedy response... ![]() Last edited by Kims Robot : 17-02-2009 at 15:57. Reason: added thoughts |
#29
The GDC has clarified a bit...I think. While I think this individual response is fairly clear, it definitely contradicts some of the other Q&A posts on this topic.
http://forums.usfirst.org/showthread.php?t=12033 So, I looks like any KOP or COTS item in "out of the box" condition are the only things not counted. This "out of the box" condition is new to me, as Fabricated to me is different than wear and specifying "out of the box" to me excludes both fabrication and wear. The Good: From this post I would include the cRio as not included as long as you bring it in it’s out of the box form. (Nothing else attached) The Bad: Nothing is all that bad. We get to bring in 40lbs of stuff made at any time. The Ugly: No matter when you wired them, any motor with leads/connectors that you bring to the event is counted toward your 40lbs. I know that some teams would normally bring a lot of spare motors. They must understand that this now counts toward their 40lbs. Last edited by Eric O : 18-02-2009 at 09:38. |
#30
The way I see the response is that you would be allowed to bring in a bunch of motors as long as they do not have connectors or anything attached to them....am i reading this incorrectly?
| Withholding allowance: Powering the cRIO | lingomaniac88 | Electrical | 1 | 12-02-2009 21:29 |
| What's going on? | Jack | FIRST Scouting Network | 0 | 17-10-2003 20:07 |
| What's going on in Jersey | Todd Derbyshire | Regional Competitions | 38 | 08-04-2003 01:35 |
| So What's Going On At GLR? | kevinw | Regional Competitions | 5 | 22-03-2002 21:38 |
