Go to Post Grease, blood and cookies... it must be build season. - danshaffer [more]
Unread 17-02-2009, 09:03
rfry11's Avatar
rfry11 rfry11 is offline
Team 2791 Head Programmer
AKA: Ryan Fry
FRC #2791 (Bionic Bison)
rfry11 will become famous soon enoughrfry11 will become famous soon enough
Send a message via AIM to rfry11
Unresponsive Limit Switches
On Sunday we hooked up our limit switches, which are essentially Vex limit switches set up to output to the Digital Sidecar's Digital I/O ports. I have them plugged into Digital I/O 1 and 3, and the colored wires are set up in this position, from left to right: White, Red, Black. We're using them to restrain the turret to a smaller degree of freedom. I have set up a very simple program that will tell me if the limit switches are pushed or not, I've attached a picture of the program. The problem that's arising is that the switches appear to be unresponsive, because they send no signal whatsoever. So, help?
By the way, sorry for the bad picture quality. Our Toshiba Satellite with a 2.5MB Trident Video Card is good at running Labview, but not so good at encoding pictures in 32-bit color
2008 Pascack Pandamonium Champions. Giant thanks to teams 25 and 11!
Unread 17-02-2009, 11:05
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Re: Unresponsive Limit Switches
Did you check the switches with a multimeter, and if so are they actually changing values when you press them?
Get yer robot source code here!
Unread 17-02-2009, 16:48
Kahn! Kahn! is offline
FRC #1379
Kahn! is an unknown quantity at this point
We blew out the DIO channels on our sidecar last night, though the rest of the sidecar still worked. Try hooking up your second digital sidecar; you may have a similar problem.
Unread 17-02-2009, 20:17
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
This may seem like a stupid suggestion, but are you 100% sure that the limit switches are being pressed? Sometimes they can look pressed but not be contacting, especially if you're using the turret itself to activate them.
The VEX limit switches are SPDT type (single pole, double throw) meaning that there is a common line that is switched between the two other lines. I believe the common line is the signal (white) and it switches between ground and +5v, but don't quote me on that. I know that the closed state of the switch connects ground to signal. Just make sure all the wires are going to the right places for the digital sidecar, as these switches were designed for the VEX microcontroller, which has all of the DIO pins pulled high, so the configuration may be different.
Edit: The SPDT function is unused, signal is attached to the NO (normally open) pin and ground is attached to C (common). This means the circuit is closed between signal and ground when the switch is pressed.
Limit Switches popnbrown NI LabVIEW 1 10-02-2009 22:39
Limit switches(in C++) beefy1 Programming 3 24-12-2008 15:27
Limit Switches ChrisR_522 Programming 2 25-01-2008 08:04
limit switches stephenthe1 Programming 28 11-05-2005 16:37
Limit switches Team168 Programming 8 10-02-2003 16:22
