Go to Post [how to read the rules] Slowly, carefully, word by word, taking your time as if it was the last corndog of the summer. - Foster [more]
Unread 16-02-2009, 21:57
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Weird issue with the power distribution block
Hey guys,
I am mentoring for a team in Chandler, AZ and we are seeing a weird issue. Even when no fuse is inserted into the power distribution block we are able to measure battery voltage across the two terminals.
We tested with a different teams robot and they were having the same issue, so it is not limited to just our team. Has anyone else seen this? Can anyone else confirm that this is the case?
Thanks,
Bert
My Blog!
Unread 16-02-2009, 22:02
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Weird issue with the power distribution block
I don't have access to our robot to check, but try putting a small load on the terminals and see if the voltage doesn't go away. Even a 1k resistor should be enough. I think there are small pull-up resistors (or similar) in there causing that effect, but there is no energy behind it.
Don
Unread 16-02-2009, 22:44
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
i cant confirm this until tomorrow, but there is a chance it might be possible that we have the same problem. we got a faulty globe motor that burned up to the point where we could not touch it for 2 hrs. It turns out that it also burned up the victor without the distinct sound of the fuse resetting.
Unread 16-02-2009, 22:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
What is the symptom with the robot that makes you suspect that the PD board is causing a problem?
Unread 17-02-2009, 00:58
The circuitry that was intended to detect circuit breakers tripping does have a tiny amount of leakage. While a good multimeter will detect the voltage, there isn't enough current to have a significant effect on anything.
Unread 17-02-2009, 11:17
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Speaking as a Mentor on the "other" bot that the OP verified this with ...
The observation that started it all was that the indicator LED on a SPIKE was dimly glowing ... even without the breaker plugged in.
We weren't really reporting a "problem" per se ... we just noticed it and wanted to see how many other teams saw the same thing.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 17-02-2009, 13:45
AKA: Bert JW Regeer
There is enough power flowing through to also have the LED lit up on the digital side car without a fuse in, and a spike where the LED was dimly lit as was mentioned in the post above this one.
My Blog!
Unread 17-02-2009, 15:27
MrForbes's Avatar
AKA: Jim
That is probably NOT enough current to allow the wires connected to the panel to melt before the breakers open.....so the breakers can still do their job.
It is an interesting phenomenon, but I don't see that it's a problem.
Unread 17-02-2009, 18:33
AKA: Bert JW Regeer
It is not about wires melting, but certain electronics generally don't like being undervoltaged. It was just a surprise to us to see that there was some power running through the system when we thought there was none at all.
My Blog!
Unread 17-02-2009, 19:00
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
If you measure the resistance from the battery + input to the PD and any of the + WAGO outputs (with no breaker installed), you should measure 100kOhms. With a "dead short" between the + WAGO output and ground, you'll only get 12/100000 = 120 microamps. That's only enough current to start lighting an LED. Any "real" current drawn by a Victor, Spike, Jaguar or Digital Sidecar will VERY quickly "turn the LED off". You can't do anything very interesting (at least in FRC, that is) with 120 microamps other than blink an LED.
Russ
Unread 17-02-2009, 19:13
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
I noticed something interesting last night pushing the robot around the warehouse between the packing crate and the scale. The motors generated a voltage that caused the wireless bridge LEDs to illuminate. Other LEDs on the sidecars, and PD also illuminated.
I don't think anything was damaged, but we will find out in 3 weeks at Orlando.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 17-02-2009, 21:26
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Jim, probably a week and some change ago we did the same thing and even had the compact rio booting, so far nothing has acted funny with our control system so I am doubtful it would have damaged anything for you guys.
For future reference though (provided you dont use crab drive, just standard 4 wheels in linear arrangement
It is very easy to push the robot from the side as opposed to front or backwards, infact it is almost easier than pushing with the motors
Unread 18-02-2009, 07:32
When you push a robot, the motors begin to act like a generator. The speed controllers (both Victors and Jaguars) use power FETs that have a diode internal to the devices. As you generate current in the motors, that current forward biases the diodes in the FETs and since they are in a bridge configuration, power is back fed to the electrical system. There is no way you can generate enough current to back feed a full 12 volts to the system, but you can generate enough to light some LEDs and make it look like you have an electrical problem. All of this is normal.
Unread 18-02-2009, 09:14
Actually, it is possible to generate more than 12V - you just have to back drive the motors faster than the 12V speed. It is hard to do this with drive motors, but possible if you have a manipulator that is heavily geared down or a bunch of students.
Another thing to consider is that when the speed controllers are being back driven through their diodes, their ability to handle current goes way down. These diodes are usually about a volt (they are worse than intentional diodes), where as when they are turned on they are usually a couple milliohms. Consider that at 10A you are dissipating 10 W instead of .1W in those FETs, and that the fan isn't on.
I have seen components destroyed this way, but it took a lot of physical effort - several students pushing a robot geared for torque (not speed) at running speed to see what happens. They got sweaty, the electronics got unhappy.
In conclusion, it is normal but not recommended.
Unread 18-02-2009, 09:39
Simple physics - where does the energy go? It's certainly not recharging the battery since the 120A main breaker is open. So... something is going to get warm and/or generate light (kinda like a different type of "warm" actually). At some power level (energy per unit time), that extra heat will cause a failure.
Try pushing a robot that's powered on (with actuators disabled for obvious safety reasons). Then try pushing a robot with the main breaker open. Any difference? There probably will be since more of the energy will be used to recharge the battery.
Good lessons to learn. But, to Eric's point, be gentle to avoid harming your robot. And never play around with enabled robots.
Russ
Splitting the Rockwell Power Distribution Block aaeamdar Electrical 4 04-02-2008 08:26
Power Distribution Block kE7JLM Electrical 4 17-01-2008 08:48
Power Distribution Block.. beemgruem Electrical 21 11-01-2008 08:11
Problems With The Power Distribution Block sanddrag Electrical 26 27-03-2007 23:11
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
