Go to Post You can never go wrong by gaining height by way of a Segway. - Elgin Clock [more]
Unread 12-02-2009, 19:50
Steigerwald's Avatar
Steigerwald Steigerwald is offline
Questionable???
FRC #0115 (MVRT)
Steigerwald is an unknown quantity at this point
Send a message via AIM to Steigerwald
Jaguar exploded resistor???
We seem to have blown a Jaguar, two in fact. Both were used on different motors with the correct fuses in place. The small surface mount resistor, R15, blew up on them and melted into another component. When tracing the leads from the resistor, it seems to go to the same trasnsistor everyone else has been having problems with.
Does anyone have this problem or a solution. We have plenty of Jaguars, so that is not the problem, we just don't want to keep blowing them.
I will post some pictures of the blow resistor later.
Thanks!
MVRT - Monta Vista Robotics Team #115
2009 Robot El Toro 13
2009 Davis Sacramento Regional Finalist
2009 Davis Sacramento Regional Engineering Inspiration Award
2009 Davis Sacramento Regional Best Website Award
2008 Championship Best Website Award
2008 Davis Sacramento Regional Best Website Award
2008 San Jose Best Website Award
2007 Davis Sacramento Regional Best Website Award
2006 San Jose Best Website Award
Unread 12-02-2009, 20:02
Re: Jaguar exploded resistor???
Please be sure to contact luminary about this. They will send you a replacement right away.
Unread 13-02-2009, 08:05
Are you sure it was R15?
Unread 16-02-2009, 02:43
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
This happened to us today. I wired up a Jaguar for CIM that runs our conveyor system. I heard a small pop and smelled burning electronics..... never a good sign.
So we tested it on one of our drive CIMs just to make sure it was dead, and the results came back positive, so we switched in our last Jaguar, but it has been running fine so far. I had heard of other Jaguars burning out before too, so I wasn't THAT surprised.
Unread 17-02-2009, 12:32
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
exact same thing happened to use today...
Unread 17-02-2009, 15:54
Drake Hunter's Avatar
Drake Hunter Drake Hunter is offline
Fighting Rednecks
FRC #2883 (F.R.E.D)
Drake Hunter is an unknown quantity at this point
We have had 4 jaguars go out on us....and where we are located express shipping is inpractical so we had to make a roadtrip 100 miles to get new ones in time to test everything before shipping
Unread 17-02-2009, 17:26
utlinebacker's Avatar
utlinebacker utlinebacker is offline
AKA: Scott Emley
no team (Texas Instruments)
Team Role: Marketing
utlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud ofutlinebacker has much to be proud of
Please contact us if these four Jaguars are different from the Jaguars you mentioned were wired improperly... http://www.chiefdelphi.com/forums/sh...highlight=jags
If wired improperly, the units will almost certainly "go out on you".
Regards,
Scott
Scott Emley
Marketing Manager
Texas Instruments
Unread 17-02-2009, 17:35
AKA: Dani
Regards,
Scott
makes sense, thats why i check everything before we power up for first times...
Also i just e-mailed you guys regarding our jaguar and provided pics...
Unread 08-03-2009, 12:51
Garii's Avatar
Garii Garii is offline
Registered Abuser
AKA: Jared Hankle
FRC #3044 (BE4)
Garii is an unknown quantity at this point
Send a message via AIM to Garii
Thanks!
sounds serious, they will send you a replacement but double check youe fuses and breaks to make sure this was the jaguar and not fualty wiring on your part.
on the other hand I DID have an issue like this with our jaguar acting strangely. it would pulse then I heard a loud "clack", followed by plenty of rotten smells =p.
I believe that they reset when they overload, can anyone confirm this for me?
-The Garii- aka Jared Hankle
Ballston Spa Labview Programmer
new team slogan-"Can I Get Some Linux With These Fries?"
Resistor for current measurement skidmarks Electrical 10 12-02-2009 10:17
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
Exploded view of FP gearbox? VEN Technical Discussion 1 13-03-2008 21:35
safety bleeder resistor teh_pwnerer795 Electrical 1 12-11-2007 20:08
Variable Resistor Problem Azash Electrical 8 26-01-2002 18:07
