Go to Post Profesional Gracism - n. the blessing said before Robotics competitions begin. - Cynette [more]
Unread 17-02-2009, 16:48
Kahn! Kahn! is offline
FRC #1379
Kahn! is an unknown quantity at this point
Re: Unresponsive Limit Switches
We blew out the DIO channels on our sidecar last night, though the rest of the sidecar still worked. Try hooking up your second digital sidecar; you may have a similar problem.
Unread 17-02-2009, 20:17
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
This may seem like a stupid suggestion, but are you 100% sure that the limit switches are being pressed? Sometimes they can look pressed but not be contacting, especially if you're using the turret itself to activate them.
The VEX limit switches are SPDT type (single pole, double throw) meaning that there is a common line that is switched between the two other lines. I believe the common line is the signal (white) and it switches between ground and +5v, but don't quote me on that. I know that the closed state of the switch connects ground to signal. Just make sure all the wires are going to the right places for the digital sidecar, as these switches were designed for the VEX microcontroller, which has all of the DIO pins pulled high, so the configuration may be different.
Edit: The SPDT function is unused, signal is attached to the NO (normally open) pin and ground is attached to C (common). This means the circuit is closed between signal and ground when the switch is pressed.
Limit Switches popnbrown NI LabVIEW 1 10-02-2009 22:39
Limit switches(in C++) beefy1 Programming 3 24-12-2008 15:27
Limit Switches ChrisR_522 Programming 2 25-01-2008 08:04
limit switches stephenthe1 Programming 28 11-05-2005 16:37
Limit switches Team168 Programming 8 10-02-2003 16:22
