Re: Filters
anyone?
Re: Filters
i would use them but i didn't even know labview had them. where are they?
Re: Filters
If you are using LabVIEW then there is a very simple solution for filters. You can use a while loop and some shift registers along with the compound arithmetic vi for a quick and dirty fix for filters. Just make sure that the shift registers are initialized to zero.
Otherwise you can use arrays and replace with array subset Vi's for a more snazzy way of averaging. |
Re: Filters
Or you can use the included filters. Be sure to use the Pt by Pt ones - the "normal" ones are meant to take a chunk of time at once, the Pt by Pt are meant to be used as things happen.
I encouraged my students to use a few lowpass filters, but I don't think they bit. |
| Kalman Filters | nickmagus | Programming | 15 | 05-09-2008 23:20 |
| Digital Filters? | archiver | 2000 | 2 | 23-06-2002 22:55 |
