Go to Post I do know a lot of teams need to be saved from themselves. - Karthik [more]
Unread 17-02-2009, 01:27
rohoRaider rohoRaider is offline
None #1817
rohoRaider is an unknown quantity at this point
Traction contron w/ multichannel PID control
Has anyone used the PID.vi with arrays? I've written it in my traction control code but it won't even deploy to the cRio for testing. Below is the error message:
PIDNChSetMemory:E on RT Target device.
LabVIEW: Failed to load shared library lvpidtkt.out:
PIDNCh:E on RT Target device.
Can anyone help? How am I suppose to use a PID with four process variables (readings from 4 encoders used as counters to measure wheel spin)?
Unread 17-02-2009, 01:33
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Traction contron w/ multichannel PID control
Use 4 separate PID loops?
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 17-02-2009, 20:41
Chaos in a Can Chaos in a Can is offline
Joel Spadin
FRC #1736 (Robot Casserole)
Chaos in a Can is an unknown quantity at this point
Send a message via MSN to Chaos in a Can
We encountered the same problem.
I do not know the cause, but for some reason, the advanced PID function for arrays didn't give us an error.
If you give it the same inputs and leave everything else at default, it should function similarly... I think.
2006 Xerox Creativity Award
2007 General Motors Industrial Design Award
2008 Judges' Award
2009 Chrysler Team Spirit Award
Using PID for traction control (help!) ellisk Programming 2 07-02-2009 14:05
PID traction Control dpeterson3 C/C++ 5 26-01-2009 21:11
PID Control John Gutmann Programming 12 15-04-2007 18:52
PID Control Chris Bright Programming 9 26-03-2005 19:44
PID Control Loops ttedrow Programming 7 05-12-2002 12:03
