Go to Post -dave "The Circular Saw of FIRST" lavery - dlavery [more]
Unread 17-02-2009, 19:48
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
15 Random Things I Learned This Build Season, '09
This is inspired by my newly finished facebook note that my friends were bugging me to complete. Here are my thoughts on what I've learned this build season, now that it's over.
  1. Project Engineers make alot of money not only because they have to know everything about the project, they also have to ensure the project's success and find a way to keep everyone busy for the project's duration. This last part is particularly hard.
  2. I figured out a metric with which to judge labor hours. Each 'function' on an FRC bot takes 10 solid hours for our team to fab, assemble and integrate with simple software. This assumes we already have the materials and are done with design and prototyping. It also precludes setup and cleanup times.
  3. Add another 10 hours if you or your team have never done that particular function before (such as conveyors), even if you have a previously-successful high-level design.
  4. Add another 10 hours if what you're doing is actually hard (such as a fancy drive train)
  5. Quadruple that 10 hours if you're all software engineers trying to create the piece of hardware.
  6. "Dewtoxification" is a real plague among teenagers.
  7. Sticking to a plan is very underrated. It was probably the only thing we did right on the first try this season. However, making a complicated plan is overrated.
  8. Consolidating strategies into a single mechanism is one key to success in FRC. We saved 10 lbs in weight when we realized that our 'secret weapon' was already on our bot due to the way our shooter is designed. Who knew?
  9. Do not powdercoat anything that deals with the production robot until as late as possible. This will allow you to weld as much as possible, which saves you time and weight in the end. This is more weight you can use for decorations
  10. Doing the hard and complicated has a good chance of success in FRC, despite popular belief. 1885 has discovered that succeeding with something that's hard and complicated results in a ridiculously fun-to-drive robot.
  11. If you want to see some motivated students, watch them be tormented by a robot that does all of its cool things while sitting in place because it's stuck on a floor component at a scrimmage.
  12. You'd rather fail at a scrimmage than fail on Thursday at competition. On the same note... You'd rather your honeycombed aluminum drive train shear at a pivot point during practice on Saturday night before ship day, rather than on Thursday at competition. At least you can pull a couple of all-nighters to fix the problems so long as it's still build season
  13. The programmers are silently begging to do cool things with software. The only way they can do it before ship day is if you give them some dedicated builders to help them create prototyping platforms for them to run on.
  14. Do not sacrifice in the quality of those prototypes though, for if the software is near perfect due to good prototypes then theoretically the code will be perfect when it's put on the robot the first time.
  15. The build students are begging to work hard to create a cool robot, if only they had an idea of what that robot should do.
GitHub
Unread 17-02-2009, 20:28
germanystudent's Avatar
germanystudent germanystudent is offline
Trashed and Scattered
AKA: Everett
FRC #2865 (Roboteknix)
germanystudent has a spectacular aura aboutgermanystudent has a spectacular aura aboutgermanystudent has a spectacular aura about
Send a message via MSN to germanystudent
Re: 15 Random Things I Learned This Build Season, '09
haha here's my list:
1) gearbox assembly is aproved by the government as a form of torture
2) gear grease tastes like an old moose
3) robots should be viewed with eyes and maybe hands but not so much the tounge.
4) always carry spare everything
5) double check for supplies needed before going to ACE
6) planning is important but the robot isn't built from plans
7) don't procrastinate
Nobody leaves my reality without a note from their mother!
Unread 17-02-2009, 20:41
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by JesseK View Post
  • Consolidating strategies into a single mechanism is one key to success in FRC. We saved 10 lbs in weight when we realized that our 'secret weapon' was already on our bot due to the way our shooter is designed. Who knew?
I cannot agree more. My favorite designs, and the ones I attempt to emulate myself, are the ones where a single system performs multiple tasks.
Unread 17-02-2009, 20:55
Seat Ninja's Avatar
Seat Ninja Seat Ninja is offline
Still waiting for the boltstretcher
FRC #0686 (Bovine Intervention)
Seat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of lightSeat Ninja is a glorious beacon of light
Send a message via AIM to Seat Ninja
Mostly. Last year i found some 5+ year old lube in the back of our shop called "food lube" for food processing (i don't have a clue why we had it). Anyway the stuff smelled EXACTLY like blue cheese, but I didn't taste it, so...
Can you play Crysis?
Unread 17-02-2009, 20:57
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
#2 umm how do you know what an old moose tastees like, just out of curiosity.
and #7 is the story of my life.
Unread 17-02-2009, 21:11
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Here's my silly list:
1. You don't wire the driver station switches that way.
2. You don't wire them that way, either.
3. You don't wire them that way, either.
4. Radio Shack toggle switches break after three solder/desolder cycles.
5. Batteries connected to chargers that are not plugged in do not charge.
6. Four CIM motors have enough torque to push two chairs, a 120lb robot, and a desktop computer across a concrete floor in the amount of time required to retrieve a dropped disable/autonomous dongle.
7. Pretty girls who can solder wires, write code, and build robots really do exist.
8. With regards to item #7, this xkcd comic couldn't be more true.
9. Military-style safety swithces actually encourage accidental toggling.
10. All that physics stuff really does come in handy.
I'll post back with my serious list tomorrow.
Unread 17-02-2009, 21:48
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Dewtoxification does not actually occur til the championships.
Unread 17-02-2009, 22:00
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
The one that stands out the most for me.
As you get older (9 build seasons and counting), the feeling of accomplishment after a long and tough build season never gets old. Its only when I look in the mirror.
Unread 17-02-2009, 22:47
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
We learned that Orbit balls don't pass Canadian safety standards. (Source: Walmart)
Queen's Applied Science '13, Applied Mathematics
Unread 17-02-2009, 23:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I learned that it's pretty hard to read the Sharpie back-of-the-hand shopping list after a day or two. It's better to get the parts on the way home!
Unread 17-02-2009, 23:04
bobwrit's Avatar
bobwrit bobwrit is offline
//No Comment
AKA: ...
FRC #1977 (Loveland High Robotics)
bobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nice
We learned that our shop walls are sound-proof to non-workers
FRC Team 1977 Alumni
Has Attended:2008 Colorado regional
2009 Colorado Kickoff
2009 Colorado Regional
2010 Colorado Kickoff
2010 Colorado Regional
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka!"(I found it!), but rather, "Hmm.... That's funny" ---Isaac Asimov
Chance favors the prepared mind ---Louis Pasteur
And you can tell me, that I can't make a diffrence because I'm just one, but one is all it takes to start it. And you can tell me, that I can't change the world because I'm too young, but I wont stand here and be your target. ---FM Static
Unread 17-02-2009, 23:35
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
Here is my list.
- Our team isn't incapable of sticking to a schedule, but somehow always get's done before ship/bag.
- This game isn't as bad as I thought it would be, judging by the build season.
- Chief Delphi is really amusing at 2:00am, along with just about everything else.
- 148 has some crazy mad robot skillz, though I suppose I actually knew this already. (also applies to 27, 968, 254, 100, 1625, and too many others to name.)
- Ship day sounds a lot cooler than bag day.
-Our team is actually capable of making an underweight robot.
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
Unread 18-02-2009, 02:42
teampronto's Avatar
teampronto teampronto is offline
ʇsı1ɐıɔ&#4
AKA: Ka'i Kau
FRC #3070 (Team Pronto)
teampronto is an unknown quantity at this point
Send a message via AIM to teampronto Send a message via MSN to teampronto
1) If you can, don't go to radioshack more than 8 times in one day.
Unread 18-02-2009, 05:00
Elgin Clock's Avatar
FRC #0237 (Black Magic)
But what sounds cooler:
Bag & Tag!
or
Crate & Wait! (for Fed-Ex to show up)
Unread 18-02-2009, 10:31
Brandon Holley's Avatar
After my 8th build season there is still much to learn...
...but the important thing to remember is to hold your head high at the end of the season and be proud of the robot you created, no matter how "good" it is. Anything you put that much time into is worth holding your head high for.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
week 1: Three Things I've Learned Jeremiah Johnson General Forum 55 04-03-2008 00:36
FIRST, Game Theory, and a few things to keep in mind this season Eric Finn Rules/Strategy 0 06-01-2007 19:18
pic: This one time during build season... katiyeh07 Chit-Chat 3 09-06-2006 17:08
Any funny things happen during the season this year? Greg Perkins General Forum 13 06-03-2002 01:35
