Go to Post Before joining FIRST, I sure wanted to be SUPERMAN or SPIDER MAN!....but after joining FIRST, I realized that there are other ways I can help people and the world. - RoboMadi [more]
Unread 18-02-2009, 00:14
Caio's Avatar
Caio Caio is offline
Caio has a spectacular aura aboutCaio has a spectacular aura about
Re: pic: Team 1538 Time Lapse
What's your robot's weight? And what material did you use for your hopper/conveyor?
Caio Tenca
Software Engineer
Founder of Washington SWAT Robotics
Ex-Team Manager, Mech. Leader of Westview Robotics Team 1510
Team 1510 co-founder
Former Team 955 member
Curie lives on in my heart <3
Unread 18-02-2009, 00:32
chaoticprout's Avatar
chaoticprout chaoticprout is offline
can't wait for next years VRC
AKA: Michael Montazeri
FRC #1138 (Eagle Engineering)
chaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant future
Send a message via AIM to chaoticprout Send a message via MSN to chaoticprout
1538 is a class act and one of my favorite teams. Great looking robot and good luck to you guys, rooting you guys on!
2009 Los Angeles Regional - Chairman's Award
2009 Granite State Regional - Engineering Inspiration Award
2007 Los Angeles Regional - Engineering Inspiration Award
2006 Southern California Regional - Regional Champions
Unread 18-02-2009, 01:25
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Our weight is 115lbs, but we're going to be losing weight. Right now we're running steel sprockets on our pick up and dumping systems, we're going to be running aluminum sprockets on the output end of the reduction.
Our hopper is built in three panels, each made of .0625" lexan. The pickup scoop, dumper backings are made of .125" lexan. We formed all of our plastic with a series of fixtures and two heat guns. It's quite easy. We spent a total of 2-3 hours cutting and forming all the plastic for one and a half robots.
Our belts are made of 5/16" urethane. We found a cheap source of cord stock and a belt welder that is half the cost of the one McMaster sells. Without these two finds we would not have used urethane. The rollers are made from UHMW tubing with aluminum end caps.
While this design looks simple, there was a lot of testing done. We originally were running 10 belts for pickup and 19 for dumping, but when we first ran the two systems we were pulling over 100 amps! After optimizing the efficiencies in both systems they now pull about 28 amps per motor. We did this by tuning the chain tension, increasing the reduction, cutting down the number of belts, testing different groove depths and widths and remaking some of the belts to be a bit loser. All in all we spent about a week optimizing our pickup and dumping systems.
Our goal with this design from almost day one was:
  • Able to pickup and score any ball, without discriminating between 'good' and 'bad' conditions.
  • Pickup effortlessly from the floor and to quickly get the balls in our hopper
  • Provide a large opening for PS to throw into.
  • Keep the hopper low so immobile alliance partners can dump in our hopper as well over/under-thrown balls to land in.
  • Fill a trailer within seconds, knowing that opportunities to score for a dumper would have potentially very narrow time windows.
  • Make sure that any balls we missed during a dump could easily be recycled back into our robot.
  • Have our exit point be high enough to score at any location around the trailer
  • Keep the number of mechanical systems to a minimum.
  • Make everything accessible and simple to repair.
So far our robot has accomplished all of these to some degree. At our pre-ship scrimmage held over the weekend we were pleasantly surprised by how many points we can score with even the smallest windows of opportunity.
Team 1538 / The Holy Cows, 2005-2016
Time Lapse Video Zholl Videography and Photography 7 19-02-2009 18:14
2006 Mayhem Time Lapse Video mizscience Off-Season Events 11 21-01-2007 21:39
Time Lapse Videos.. Tom Schindler Chit-Chat 4 21-12-2006 08:37
A380 assembly time lapse Peter Matteson Chit-Chat 11 24-03-2006 06:43
US Air Traffic time-lapse Brandon Martus Chit-Chat 1 09-05-2003 01:09
