Go to Post Friends don't let friends prototype alone. - SenorZ [more]
Unread 18-02-2009, 02:28
LVMastery LVMastery is offline
LabVIEW Educator and Mentor
AKA: Ben Zimmer
FRC #0843 (Wildcats)
LVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud of
Lightbulb So, honestly, who's still programming?
Hey Everyone,
I had several conversations yesterday with mentors from teams who are either:
- withholding their controller and a few sensors and actuators from shipment to do further programming work between now and competition
- planning to program blind (without hardware) and cross their fingers that they can tweak it on compliance day
Being a rookie mentor (though LONGtime LabVIEW programmer) I didn't honestly consider these options as viable.
However, if I can help by producing one or two more LVMastery TipJar videos in the meantime, I would be happy to.
Please reply to this thread if you have a topic in mind.
Thanks,
Ben
www.LVMastery.com/FRCTipJar
Ben Zimmer
Enable Education
www.EnableEducation.com
www.FRCMastery.com
email: ben@enabletc.com
Phone/Fax: (905) 864-1858
Toll Free: (877) 872-4619
Unread 18-02-2009, 08:31
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: So, honestly, who's still programming?
1629 is still tweaking. Something that annoys me about our code is that I run a pid loop for the wheels (in periodic tasks) and during the disabled period, any latent movement causes the pid to burp when restarted.
Wondering the best way to reset the pids and ramp functions during disable.
Phil Malone
http://www.GEARSinc.org
Unread 18-02-2009, 08:35
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
Originally Posted by LVMastery View Post
Hey Everyone,
Thanks,
Ben
Oh, please do one on how to program the other buttons on the Joystick. We have our robot moving forward and back and it turns, using 2 joysticks, but we cannot for the life of us get how to do a trigger (using the KOP joysticks). We want to do the following:
1. Right hand joystick trigger - make the globe motor move the chain forward.
2. Left hand joystick trigger - make the globe motor move the chain backwards. This only is used if something gets stuck.
3. Button that thumb rests on (right hand) make the keyang motor move the dumper forward.
4. Button that thumb rests on (left hand) make the keyang motor move the dumper back. This is only used if a ball gets stuck
I found out that the dumper is using the Keyang motor and the chain is using the globe motor and the drive motors are the CIMS.
I really have no idea how to continue. I have watched all the TipJar videos, but not understanding the engineering part makes programming difficult. This is the first year the mechanical has been done before the code.
Please, can you help??? We go to Traverse City next Thursday (26th)
Thanks.
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
Unread 18-02-2009, 08:46
AKA: Ben Zimmer
One thing I would consider is using the reinitialize input of the PID Control Input Filter.vi and PID.VI itself. You could use a global to send an enabled boolean from the main loop which is true when teleop is enabled and false when disabled. Or,
As an aside, and for all of the people asking about Joystick Functions: there is a fantastic function inside the OpenG Library called Boolean Trigger. It will output a momentary boolean high when the input value has a rising (and/or falling edge) which makes trapping a change of state a lot easier.
Naturally ( ) I have a TipJar entry discussing the OpenG library and how to install it: http://www.lvmastery.com/TipJar2008-03-13
Ben
Ben Zimmer
Enable Education
www.FRCMastery.com
Unread 18-02-2009, 08:50
AKA: Ben Zimmer
Thanks.
Please see the attached snippet. Basically this shows how to extract the button values, and also shows using the OpenG Boolean Trigger function (see my other reply below) Hope that helps!
Ben
Name:	Example Teleop.PNG
Ben Zimmer
Enable Education
www.FRCMastery.com
Unread 18-02-2009, 09:48
FRC #1254 (Entropy)
Thanks, I will try that.
Carolyn
Unread 18-02-2009, 12:50
fritzdejongh fritzdejongh is offline
Coach
FRC #2704
fritzdejongh has a spectacular aura aboutfritzdejongh has a spectacular aura aboutfritzdejongh has a spectacular aura about
How about an intro to the pid library?
We haven't looked into it yet, and some examples of what it's good for would help us figure out if we should apply it in our code.
Unread 18-02-2009, 14:00
FRC #1254 (Entropy)
Where do I check the version of the WPI Library we have?
Unread 18-02-2009, 14:03
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
If you are programming in Labview then you don't need to worry about WPI Library version. You only need to worry about Labview version, cRIO image version and Driver's Station image version.
Unread 18-02-2009, 14:05
FRC #1254 (Entropy)
We are using Labview (or at least trying to) so we will not worry about that.
At least one less thing to do.
Carolyn
Unread 18-02-2009, 16:02
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Another option is to take the "Robot Mode" from the Robot Basic Mode.vi and add it as a global. Then put your PID(s) inside a state machine(s), controlled by the "Robot Mode" global, that only allows it to run during the enabled modes.
Now as for the original question by the OP; We are!
We will be working blind, but we have a copy of the code we "finalized" before shipping, that we are satisfied with for now.
We will be adding a few minor modifications to copies of the code to: refine our autonomous, add "Alliance Color" lights on the operator control panel and lights that indicate "Tracking" to the control panel as well. We may also add a switch to the control panel to indicate to the robot what alliance we are on in the case the FMS does not provide it to us. Without knowing which alliance we are on, our robot will always track BLUE. (A little insurance is always a good thing.)
Unread 18-02-2009, 21:56
Kahn! Kahn! is offline
FRC #1379
Kahn! is an unknown quantity at this point
I would also like to see this.
We are programming, blindly. The rest of the team is making me and my fellow programming another kitbot for testing and from there we hope to get everything working before competition. Sadly, our design team's decision to finish the robot the day before ship wasn't exactly what we had planned for.
Unread 20-02-2009, 14:22
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
were still fine tuning our sonar, which is also our autonomous, oh and the driver station, were slaving over that.
Is now an engineer thanks to FIRST.
Unread 21-02-2009, 04:24
Arcre Arcre is offline
jp
AKA: Jorge
FRC #2504
Arcre is an unknown quantity at this point
Still programming, we have a programming bug where we temporary stop the robot for 3 seconds when we combined our joystick control with 2 button control speed drive. Should I email my code to you for debug?
Unread 22-02-2009, 18:50
FRC #1254 (Entropy)
We are still working on adding features and awaiting the time when we can test our first program.
Last edited by chinckley : 22-02-2009 at 18:52. Reason: was going to add more but decided not too.
Who's still alive?? I am!! AdamT Chit-Chat 7 15-12-2004 22:08
Who's Blue? Who's Red? WebWader125 General Forum 22 08-03-2004 22:24
