Go to Post If they don't treat Dave nicely, he may just keep his big red ball, and not share with rest of us. - Barry Bonzack [more]
Unread 17-02-2009, 22:37
rdlevy1215's Avatar
rdlevy1215 rdlevy1215 is offline
FRC #1676 (Pascack Pi-oneers)
rdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud of
2009 Team 1676 Robot
Here it is: The 2009 Team 1676 Robot: Apollo!
To see more, including one with it's faternal twin, click HERE.
Robert D. Levy
Team 1676, "Pascack Pi-oneers"
http://www.team1676.com/
admin@team1676.com
Unread 17-02-2009, 22:42
Re: 2009 Team 1676 Robot
Another great robot from our sister team in Pascack Valley!!!
Just curious, will there be another Pascack Pandamonium this year?
MORT + Pioneers = <3 ^_^
Unread 18-02-2009, 08:20
rdlevy1215's Avatar
Pascack Pandamonium is right now in a TBD state .... we do not know if it will happen again this season.....
Robert D. Levy
admin@team1676.com
Unread 18-02-2009, 12:33
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Its beautiful, but I would like to pose the question to CD'ers: Does doubling up the wheels help traction? I'm don't think it does because each wheel has half the weight and the force available is the weight times the coefficient of friction.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 18-02-2009, 13:23
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
Did I get this right: do you just store a few balls down low when you collect them with that roller, spit them out to Human Player, and they load the top of your bot? Interesting strategy, haven't really seen this yet. Good Luck, always expect a contender from 1676.
Cold Fusion's 10th Season
Unread 18-02-2009, 13:29
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
Adding wheels does not change traction. It just lowers force Normal, and just gives each wheel less traction.
(Static) Friction = coefficient Friction * Force normal
Unread 18-02-2009, 15:15
BGiraud's Avatar
BGiraud BGiraud is offline
AKA: G
BGiraud is a splendid one to beholdBGiraud is a splendid one to beholdBGiraud is a splendid one to beholdBGiraud is a splendid one to beholdBGiraud is a splendid one to beholdBGiraud is a splendid one to beholdBGiraud is a splendid one to beholdBGiraud is a splendid one to behold
True. In theory the traction should not change. In practice, more contact patch wil make a small difference. We staged a tug of war between our twins. Both at 120 lbs. One had 12 wheels and the other had 6. It was a tie. Theory wins!!! But, when we drove them there was a noticable difference. The one with 12 wheels was more controllable. You could see it and the drivers could feel it. Both of our drivers requested the 12 wheel configuration for competition, but the 6 wheels for fun. The six wheel set-up turned faster and a bit more uncontrolably. Other tests proved that acceleration and turning were simillar, but stopping (sideways slide) was much better with 12 wheels.
Since we came in under weight we decided to keep the 12 wheels. In the end we all agreed that they look cooler than six. If weight was an issue then we would have dropped it to six wheels.
Verdict - There is definately something to be gained by increasing your contact patch. It might give you a slight edge, but it isn't a game breaker. I have found that this holds true for rubber on carpet in previous years as well, but that is another story. One that many theorists would like to argue I am sure.
Unread 18-02-2009, 15:39
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I believe that may be a result of where you're making contact, rather than the size of the contact patch. The second set of wheels, which I'm presuming are the inside set, is closer to the center of mass of the robot.
Any force transmitted via the inside set of wheels will have less torque on the bot as a whole. As such, the bot will have less turning power, and thus easier to control.
Unread 19-02-2009, 08:18
BGiraud's Avatar
AKA: G
Actually, the second set is the outside set. Your point is well received though. I need to think about the implications of contact location. As an aditional note. The middle wheels are rockered down 1/16". Tests with no rocker yielded poor results. Too much friction during turning.
Team 701's 2009 Robot Steven Sigley Robot Showcase 3 06-03-2009 20:32
Team 1629 2009 Robot E. Wood Robot Showcase 2 24-02-2009 22:29
Team 968's 2009 Robot kiettyyyy Robot Showcase 27 20-02-2009 11:05
Team 11's 2009 Robot Akash Rastogi Robot Showcase 13 19-02-2009 00:25
Flash of Robot 1676 Spiffizzle Robot Showcase 0 10-02-2006 19:49
