Go to Post "But from a real life standpoint, that looks like something the evil villains in a superhero movie would use to get around in" Reading the phrases "real life" and "evil villains in a superhero movie" in the same sentence makes me giggle. - Alan Anderson [more]
Unread 18-02-2009, 19:55
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
LabVIEW annoyance. help( not a hater thread)
Ok so now that we've got our robot working and shipped out we have been working to get things to be better and more optimized. I have read through the nI board and some LabVIEW books but I seam to have 2 small issues.
so my biggest annoyance is with the deploy all function.
A) is there any way to get the front panels on all of our sub VI's to NOT pop up when we deploy all( we have 20+,and I think its causing PTSD on my Vista laptop ).
B) from Build ,to Deploy all ,to a robot reset, it takes 5:45( yes we timed it) . . can I make this smaller . . like down below the 2:00 mark.
Any advice would be great.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 18-02-2009, 22:01
Re: LabVIEW annoyance. help( not a hater thread)
Are you picking the Deploy menu item from the right click menu on the Build Spec? Or is this a different menu item?
As for the build time, if you have started using analysis VIs, you may find it useful to edit the build spec deployment, click to the Additional Exclusions tab, and check the item to exclude library items not being used. Don't modify the library files.
Greg McKaskle
Unread 18-02-2009, 22:39
Stuart's Avatar
#include coffee.h
ahh ahh thanks for the no popups . . Ive been Deploy All from right clicking on the cRio.
yeah I checked the exclude unused library files. no real change in build time
Unread 19-02-2009, 01:13
I too would love to make the Build process run faster. It takes between ten and fifteen minutes to build our code using our several-year-old laptop running Windows XP. Checking the "exclude" box Greg suggests made no noticeable difference. I don't think we're using any of the Analysis VIs anyway.
I have no idea how long a Build takes on our new Windows Vista laptop -- it fails to build, giving an Error 8 (possible file permission error), and I haven't finished troubleshooting it.
Unread 19-02-2009, 09:22
Wow. Mine takes up to two minutes on either of my machines (now that I've changed my build spec). Neither of my boxes are particularly impressive - one is 5 years old.
Unread 19-02-2009, 11:40
I have the same problem with the team T-30 laptop taking 10 minutes to build and download. I haven't had time to look into the resources that must be maxing out.
I switched to my newer work machine and it goes much faster, but that's problematical, since I'm really the only one who can use it.
Time to look for a grant for a new team laptop.
Unread 19-02-2009, 11:56
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
My wait is about 5 minutes for the whole process. I usually right-click the build spec and click build, and after that, run as start up. I'm not sure if this is the normal procedure, but it works for me.
Twitter Profile
Unread 19-02-2009, 13:10
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
I dont understand why the whole compiling and downloading process takes so much longer than it has in previous years. granted, the programs are much more complex, but shouldn't most of the libraries be cached on the RIO anyway?
when we go to download test code (running from the main vi, not deploying), the rio spends like a minute downloading all of the supporting vi's, and then downloads all of the project files- even if all we did between tests was change a wire!
the way labview works is really weird in my opinion... yet its so powerful...
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 19-02-2009, 13:55
I resolved the Error 8. I had copied a project from our Windows XP laptop to the Vista laptop. and the output file directory in the project's build specification wasn't compatible with Vista's filesystem structure.
Now it only takes nine minutes -- a noticeable speedup, but still unreasonably slow. It shows the "Initializing build. This could take several minutes..." message for more than Eric's two minutes, and a totally new Basic Robot project runs the build for another two minutes. This is on a 2 GHz AMD Turion 64 with 3 Gigabytes of 800MHz SDRAM. What the heck is going on here?
Unread 19-02-2009, 20:18
I wasn't able to look into this today, day jog kept getting in the way. I hope to gain some insight, and hopefully a solution tomorrow. I currently can't explain or justify the time it takes. I looked into the one issue with the analysis libs and the checkbox and can pretty much explain that one. I'll certainly post as soon as I understand it.
Greg McKaskle
Unread 19-02-2009, 22:36
I turned off the virus scanner on our nice new Vista machine, and build time for our full project dropped drastically to just over three minutes. Mystery solved, I guess.
I checked the old XP laptop with 10-15 minute builds, and it only has 256 MB of RAM. Might that explain the extreme slowness?
Unread 20-02-2009, 08:30
That is helpful in more ways than one. The virus checker is concerned anytime disk activity is taking place, so this also points in the direction of overly disk bound activity.
The LV build used to be so simple. LV VIs are already compiled and the .o is bound inside of them. The files were aggregated into a primitive zip called an LLB, that was attached as data to the end of a tiny EXE wrapper that knew how to load the LV runtime engine, and we were off to the races. If you wanted it smaller, the other parts of the VI were stripped of diagram and some panel info.
With libaries, lots of things changed while I wasn't looking, so let me investigate. I'd like it to take less than a minute. I don't see why the build should be slower than the download.
By the way, noticed in my other post that I had a typo
Hah, day job is what was getting in the way, I haven't jogged in years.
Greg McKaskle
Unread 20-02-2009, 09:10
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
but im guessing the code compiled in these .o and exe wrapper segments are for an x86 processor, not for the processor contained in the rio? is this why it takes so long?
RPI 2012
BREAKAWAY
Unread 20-02-2009, 09:16
Stuart's Avatar
#include coffee.h
no I would expect that these .o files are for the power PC( its a power PC right?), although I do reserve the right to be wrong. Im curious to see if any one still has update 1 or update 2 on their computers, see if the change in the libs too place during that time.
Unread 20-02-2009, 10:23
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Alan, something is very very wrong. My laptop (purchased off ebay for $150) is a 1.6 celeron with 1 gig of ram. It takes 2-3 minutes to deploy to the crio.
Just for clarification, that is a Robot Main -> Run arrow deploy. Not a complete build and download so that it runs on startup. We've only done that once this season
LABVIEW CODES NOT SAVING!!!!!!! PLEASE HELP!!!!!!!!!!!! GrammarNazi Programming 3 06-02-2009 14:26
I'm trying not to hate labview but... sparrowkc NI LabVIEW 14 22-12-2008 22:41
Activation of LabView still not working apollorest National Instruments LabVIEW and Data Acquisition 4 22-11-2008 21:09
frc_camera not working but labview does Issues Programming 7 18-01-2006 19:23
Audioscrobbler.com -- Go sign up! -- This is not like the other thread. Ashley Christine Chit-Chat 56 26-10-2005 17:41
