Go to Post It's kind of magical how I went from legos to replacing most of the iron in my blood with aluminum, and all thanks to my elementary school science teacher. - Astrokid248 [more]
Unread 22-01-2009, 04:41
May_Walter's Avatar
May_Walter May_Walter is offline
Artemis #3083
FRC #3083 (Artemis)
May_Walter is an unknown quantity at this point
A few Questions about Lunacy
Hello, we have read the manual, and some things were still left unsaid for us..
1. Can an adult join to team as a payload specialist (the one that throws the moon rocks..)?
2. Is the an age limit (below or under a certain age)?
3. How can the payload specialist located in the outpost get new moon rocks after using all of the 20 balls he stated with? I mean, after the robots transfer the ball back to the fueling posts, how can he get the balls?
Thanks a lot,May Walter,Team 3038.
Unread 22-01-2009, 06:33
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: A few Questions about Lunacy
1. Section 7.2 DEFINITIONS states that a Payload specialists must be a pre-college student team member
2. There has never been an age limit, although it is a high school robotics program.
3. G20 states: MOON ROCKS can be recycled to the PAYLOAD SPECIALISTS by passing them over/through the AIRLOCK and through the FUELING PORT in the Alliance Station Wall, or by passing them through the port in the OUTPOST shield. MOON ROCKS can not be recycled to the PAYLOAD SPECIALISTS via any other paths (e.g. over the OUTPOST shield or Alliance Station Wall). A violation will cause a PENALTY to be assigned.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 18-02-2009, 16:53
KTjen2967 KTjen2967 is offline
FRC #2967
KTjen2967 is an unknown quantity at this point
So does anyone know how many pilots are needed (other than two), or if there is a maximum number? We know that there are two pilots per robot and team, but that's only per round; so what about the total number on a team?
Unread 18-02-2009, 17:08
JYang's Avatar
JYang JYang is offline
AKA: Jenny
JYang is just really niceJYang is just really niceJYang is just really niceJYang is just really nice
A team usually has two pilots per robot. However, you cannot have more than two pilots per round. If your team wants to rotate pilots, that is allowed but not many teams do that because it is better to have one set of pilots who know what they are doing especially for the eliminations.
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
I suggest that if you want to be remotely competitive at comps you keep the same drivers(pilots) for every match(round). Switching drivers every match is going to cause you to have non-consistent performances on the field. Consistency is the only way you will be able to be competitive and win.
Unread 18-02-2009, 17:09
There are no limits to how many pilots (drivers/operators/whatever you call them) you have on your team, but you can only use two in a match. Having backups is highly encouraged. If your primary isn't able to go, and you don't have a backup, you're going to be hurting.
Unread 18-02-2009, 17:13
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
The way this works at the regionals (unless they've changed it this year) is that your team will be issued four player buttons when you check in on Thursday, one of which is marked (usually with a dot) as the Commander/Coach button. In order to represent your team on the field, you must have the button on. The person with the Commander button can't touch the controls, even if they are a student. If you want to change who is playing in your next match, just hand off the button or buttons. It's very important not to forget them at the hotel overnight because you can't play without them (but someone does at every regional, every year and has to make an emergency run back to get them before their first match... save yourself some panic and keep track of your player buttons).
Unread 18-02-2009, 20:01
Mr_D_Mentor's Avatar
Mr_D_Mentor Mr_D_Mentor is offline
AKA: Frank D'Anna
FRC #5856 (The Bullbots)
Mr_D_Mentor is on a distinguished road
The payload specialist must use the grabber to get the balls from the fueling station into his/her hands. The grabber is about 2 feet long and is tied to the super cell rack with a string that's about 1-1.5 ft long.
8th year mentor
Bullbots, First Team #5856
The Nuts & Bolts of Fury, FIRST Team #3525
Team MAX, FIRST Team #1071
Unread 18-02-2009, 20:03
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Unfortunately that is not the question that was asked.
The payload specialist located at the Outpost does not have a grabber and as far as I know cannot be refueled.
EDIT: Thanks for the correction Eric. The Outpost Payload Specialist may be reloaded through the hole in the Outpost shield. See Eric's post below.
Unread 18-02-2009, 20:20
Sorry, Vikesrock. The Manual wins.
Though the PS at the outpost doesn't have a grabber.
Unread 18-02-2009, 20:27
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
"Recycling" apparently refers to robot-PS interaction. It seems to me that the rules do not prohibit the Fueling Station PS from throwing game objects over the wall to the Outpost PS. It's a long shot, but could happen.
Unread 18-02-2009, 20:31
Sorry, Rick. http://forums.usfirst.org/showthread.php?t=11436
Extra long shot, but could still happen.
Unread 18-02-2009, 20:56
Oh darn, foiled again. I submit that such a shot is absolutely impossible (unless you allow ricochets off robots).
A few questions Magnechu Rules/Strategy 8 25-01-2008 17:01
A few Questions about Omni Wheels.... kSniper Technical Discussion 4 08-01-2008 00:15
[OCCRA]: Few questions about the competition Adam11 OCCRA Q&A 0 13-09-2004 20:38
A few questions cheezewiz Programming 7 31-01-2004 00:02
A few questions goegan31 Regional Competitions 1 09-03-2003 20:32
