Go to Post Ok, so you are going to use a robot to hold all of those rivets together? - gblake [more]
Unread 17-02-2009, 04:28
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Wireless debug print ??
We are using C++ and want to use debug print statements to send data over the wireless data link and display it on a laptop.
We are aware of the LCD print capability and use it for small prints but large data dumps require a laptop. We have the TCP/IP communications going, but not quite sure how to send things to the Terminal window.
Does anyone have some sample code for this.
Unread 17-02-2009, 10:25
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: Wireless debug print ??
Juse use printf and to see the output, open a target console. Right click on the target, select "Target Tools" and "Console". You don't have to be running in debug mode to see the output.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 17-02-2009, 18:47
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
Brian
We tried that, but it didn't work. The console it brought up was completely blank. There were no error messages or anything (at least not that I recall) that might indicate what happened.
Which badges can you claim?
Unread 17-02-2009, 19:00
radau radau is offline
radau is an unknown quantity at this point
Brian
They want to use wifi to retrieve the output, which (using printf) is spat out to the serial on the cRio (which requires a physical connection). You could use a serial/wireless adapter ($100) .
Or maybe if you write your debugging messages to a file on the cRio, you can retrieve them by ftp-ing to it wirelessly (10.te.am.2, using "root" and no password). You could probably even watch the file grow as if it were real console output, using something like ftptail.
Here's the code you need to write stuff to files:
#include <stdio.h>
#include <stdarg.h>
FILE *debugf;
 * Use this like you use printf! (e.g. debug("Gyro heading = %f", gyro->GetAngle());).
void debug(char *msg, ...)
	if (debugf != NULL)
		char buf[256];
		va_list args;
		va_start(args, msg);
		vsprintf(buf, msg, args);
		va_end(args);
		fputs(buf,  debugf);
		fputs("\n", debugf);
 * Put this in IterativeRobot::RobotInit!
void debugInit()
	if (debugf == NULL)
		debugf = fopen("debug.txt", "w");
I haven't tried this! The advantages of writing to files is that it creates significantly less overhead than printfs, but I dunno about overhead caused by ftptail.
Unread 18-02-2009, 20:47
SuperBK's Avatar
AKA: BrianK
We get the output to the console wirelessly. Always have since the beginning. Our "console out" switch is on, if that makes a difference.
Brian
Brian K
Unread 18-02-2009, 21:14
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
For wireless debugging I wrote to the console output using standard iostream:
std::cout << "Variable 1: " << var1 << std::endl;
Worked great, right click the target in wind river, target tools, remote console. Make sure the console output switch is turned on.
My Blog!
Unread 18-02-2009, 21:28
agough's Avatar
agough agough is offline
FRC #0234 (Cyber Blue)
agough is an unknown quantity at this point
I am searching for the way to activate it and i can't find it.
Is it the same for wireless download or is that a different thing altogether?
"By failing to prepare, you are preparing to fail."-Benjamin Franklin
"Wise men talk because they have something to say; fools, because they have to say something."-Plato
Unread 23-02-2009, 00:21
AKA: Bert JW Regeer
When you set up a debug connection using the instructions in the PDF that is supplied you can right click on the remote connection, after you connect to the remote target, you can then from that same menu select remote console.
My Blog!
Debug Windriver issue..... programmr C/C++ 12 06-02-2011 13:47
Sidecar Debug NinjaSpawn94 NI LabVIEW 6 07-02-2009 10:48
SERAL INSTEAD OF DEBUG... EGG0900 Programming 2 05-11-2005 18:25
IFI Dynamic Debug Tool fowlerm Programming 0 25-08-2005 16:18
Debug function in programming? archiver 2001 4 24-06-2002 00:34
