Go to Post Besides, you know hard it is to solder with gloves on? - Al Skierkiewicz [more]
Unread 18-02-2009, 21:39
ERROR 401 ERROR 401 is offline
ERROR 401 has a little shameless behaviour in the past
Auto Code
We are having a problem with the auto code in LV...
Could somebody please just post a screen shot of there auto code just so we can see how you set it up??
We think its a watchdog failure but now sure.
We also tried just loading the default CRIO project code and we enable the T F statement in auto independent
Any ideas why are auto won't enable with default code??
Thanks
TechTigers
Unread 19-02-2009, 00:53
Re: Auto Code
If I try to test the default Autonomous Independent VI by clicking the Run arrow on the Basic Robot Main VI, most of the time it works, but sometimes it won't enable. It never enables when I'm using the older slow programming laptop, so I figure it's an issue with the program running too slow to feed the watchdog properly when the front panel windows are open.
EasyC for FRC: Drive and Auto Track Camera Code Kingofl337 Programming 7 08-01-2007 15:30
auto Tachion FIRST Tech Challenge 3 17-11-2005 11:25
AUTO TRACKING!!!!!!:( magical hands Programming 15 15-02-2005 19:27
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
[white paper] Auto-Balance Gyro Code Brandon Martus Technical Discussion 3 21-06-2001 10:36
