Go to Post Please don't confuse energetic enthusaism with acting obnoxious. - Alan Anderson [more]
Unread 19-02-2009, 10:39
Re: WatchDog Timeout
Use the default autonomous program as a guide.
It does, however, fail to feed the WatchDog immediately, so running it as is will get you the disabled blink right away.
The True/False input to the whole thing needs to be set to True for it to work.
You'll see the WatchDog is feed inside the loop that runs for 5 seconds, after which it leaves and stops feeding the WatchDog, so the blinky light will show up after 5 seconds.
Watchdog darty NI LabVIEW 8 16-02-2009 09:11
error 5101 : Timeout Wynlyndd LabView and Data Acquisition 3 31-01-2006 14:05
Timeout!! Ricky Q. Rules/Strategy 19 01-04-2004 22:03
Microsoft Timeout AJ Quick Regional Competitions 12 09-03-2003 17:38
Timeout Ruling Discussion ram Off-Season Events 4 29-11-2001 13:38
