Go to Post Naw, basketball isn't nearly as great a sport as FRC. They play for the money. We play for honor, dignity, and respect. - synth3tk [more]
Unread 19-02-2009, 14:02
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
2 sets of bumpers legal?
Our team colors have always been red and blue. This year we built 2 complete sets of bumpers for our robot. One red set and one blue set. We would like to be able to swap out the bumpers from match to match depending on if we are on the red alliance or blue alliance simply to match the alliance color (and the color of the trailer we are attached to). I am wondering if other teams have done this in the past and if it is legal. How would multiple sets of bumpers be viewed in the rules and during inspection? Would they be like batteries that you are allowed to swap in and out as desired or would they be considered alternate configurations of the robot? Is one set a spare or do both sets have to be weighed in at the same time and be less than 18lbs collectively? I have read the rules and can see it being called either way. Bumpers like batteries are not part of the robot weight and so I wouldn’t think they would be considered an alternate configuration, however, bumpers have their own weight restrictions and batteries do not. Our two sets of batteries will not make the 18lb limit collectively but each individual set do, of course. What rules would govern this situation?
Unread 19-02-2009, 14:04
A Bear's Avatar
A Bear A Bear is offline
FRC #2333 (Roboswitch Engage)
Team Role: Student
A Bear is an unknown quantity at this point
Re: 2 sets of bumpers legal?
I think so but im not sure...i want dual bumpers lol
Unread 19-02-2009, 14:06
Joe J.'s Avatar
Joe J. Joe J. is offline
My Gaming Is FIRST!
AKA: Joey
Joe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond repute
Send a message via AIM to Joe J.
Sounds like a Q&A question to me. Though I seem to remember hearing of teams doing this in the past.
Joe Jagadics
Lead Mentor / Coach
Lightning Robotics FRC Team 862
Unread 19-02-2009, 14:07
Answer #1: Go to Q&A.
Answer #2: It was fine last year (under last year's rules, which are not the same as this year's).
Answer #3: I would guess that they'd be illegal because they don't make weight together. Why do I say that? <R13> says that you have to weigh all possible configurations (of the robot) together.
Answer #4: Hi ho, hi ho, it's off to Q&A we go!
Unread 19-02-2009, 14:10
A Bear's Avatar
Team Role: Student
but i thought bumpers dont coult for the weight....
Unread 19-02-2009, 14:12
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Bumpers are not part of the weight referenced in <R13> though. Additionally you don't have to weigh spare parts, just alternate configurations. I think would qualify as spare parts rather than different configurations.
Unread 19-02-2009, 14:13
They don't. They have their own weight limit of 18 lbs. The question is whether <R13> applies only to the robot or applies to the robot and the bumpers independently.
Of course, then there was one team with two sets of bumpers who didn't pass inspection last year... but they had other issues with inspection.
Unread 19-02-2009, 14:15
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
If you're referencing 1519, that's a completely different issue. Let's try and keep that issue apart from this one to avoid confusion.
Unread 19-02-2009, 14:17
You're probably right. However, some of the Q&A rulings this year have been...well...surprising, to say the least. Note that the first and last answers I gave were suggestions to go to Q&A, primarily because there are valid points on both sides.
I'm hoping it's legal, but at the same time, I can see it not being legal.
Edit: Sean, part of the reason for that was the second set of bumpers, IIRC. However, we will leave that alone now.
1038 would be a better example.
Unread 19-02-2009, 14:20
wo-bot 141's Avatar
wo-bot 141 wo-bot 141 is offline
AKA: cory walters
FRC #0141 (WO-BOT/COLD LOGIC)
wo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to behold
I have seen teams in the past switch out bumpers. for example... wildstang switched bumpers in the elimination rounds in 2006 if I recall. all i think you would have to do is weigh them both so the are both legal. Still i would got to Q&A to be sure. but like i said you should be fine.
Unread 19-02-2009, 14:21
In 2006, bumpers weren't required. They could have run without them if they wanted. Still, Q&A.
Unread 19-02-2009, 14:23
I'll ask a Q&A when I get back in town next week and can find our password to the Q&A forum. I was just curious if this has been done by others in the past. I can see it going either way. One set isn't really a spare set in this case since the plan would be to swap them from match to match. To me a spare is to REPLACE a broken part. Once the broken part is replaced with a spare the original part even if it is fixed can't be put back on the robot again right because that would be a way around the alternate configuration rules. They really aren't an alternate configuration in my my mind because they aren't like two different mechanisms that provide two different functionalities. They are identical other than color.
Unread 19-02-2009, 14:31
wo-bot 141's Avatar
AKA: cory walters
Right they were not. we didn't like the idea of bumpers so our team decide not to put the on so we could have more kinetic energy with the robot.
Unread 19-02-2009, 15:15
Jared Russell's Avatar
Taking a year (mostly) off
Provided the other set of bumpers was functionally identical (and I would argue that color has nothing to do with function when it comes to bumpers), I believe that these would be spare parts and so unrestricted.
But what I say means nothing...ask the Q&A.
Unread 19-02-2009, 15:52
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
We were one of those teams over the last two compeition seasons (Rack-n-Roll and FIRST Overdrive) that had color changing bumpers. In both instances they were legal as long as each set was built to spec. But, with the all of the bumper issues this year, I would definantly check with Q&A.
We decided against this year because our graphics team wanted to make sure the bumpers fit into the color theme of the robot graphics, website, buttons, etc.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Segway sets course for stock market Melissa Nute Dean Kamen's Inventions 4 30-05-2006 10:30
How 1072 sets off fire alarms whakojacko Robot Showcase 3 23-02-2006 18:40
Vex and Erector Sets? jeffmorris FIRST Tech Challenge 1 03-10-2005 13:16
Rookie Allstars: what sets you apart? Greg Needel Championship Event 1 07-04-2005 16:48
Dean sets IT release date! archiver 2001 4 24-06-2002 01:43
