Go to Post Learn all about the alternatives, and choose wisely; don't rush the decision--this is too important to your success to make a mistake. - Tristan Lall [more]
Unread 16-02-2009, 15:38
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
Re: Update #12 - software/firmware
Originally Posted by JamesBrown View Post
What are you referring to, WPILib?
Yes. Listed in Update #12 are 4 things we need to make sure are updated:
Software/Firmware Revision
Labview for FRC Update 3.0a and newer
cRIO FPGA Image FRC_2009_v11.zip and newer
WPI Robotics Library 3.0.1718 and newer
Driver Station 2009-02-010a3 and newer
These were updated in Update #12 (the ones in RED)
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
Unread 16-02-2009, 21:10
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
See http://first.wpi.edu/FRC/frcupdates.html
Zan Hecht
Unread 17-02-2009, 09:01
FRC #1254 (Entropy)
Originally Posted by ahecht View Post
Do we update the WPI Library if we are using Labview?
When I clicked the above link it said C/C++.
We did update the DS last night and it worked.
I see the correct Labview update we did.
How do I tell if I have
cRIO FPGA Image FRC_2009_v11.zip and newer?
If I need it where do i GET IT?
Do we do all these things:
Came from above link.
Downloads
Workbench Updater: WorkbenchUpdate 3.0.1718.exe (19Mb)
Source code for vRC0.1718: WPILibRC0.1718SourceCode.zip (372kb)
(remember that this will only work with the FRC_2009_v11.zip cRIO image, below or with LabVIEW update)
cRIO Image updater (stand-alone without LabVIEW) - FRCNIWRUpdate3.0.a.zip (90.5 Mb)
Documentation - also located in c:\windriver\docs\extensions\FRC after the installation - FRC1718Docs.zip (17 Mb)
C++ Reference as a Windows Help file with hyperlinked class diagrams
C++ PDF Reference document
C PDF Reference document
FRC Vision Windows Help File
FRC Vision API Specification
Thanks
Unread 17-02-2009, 10:52
Back after 4 years off
FRC #5279
You only need to update WPILib if you are programming in C/C++
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 17-02-2009, 11:56
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Another major change is the no wireless except on the competition field.
This means tethered in the pits and on the practice fields. Make sure you have access to the ethernet port on the cRIO. We had to move ours to make it easier to plug/unplug as we came back to the pits at Suffield Shakedown.
So now I go off to buy a long ethernet cable for practice.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 17-02-2009, 12:19
FRC #1254 (Entropy)
Thank you so very much.
Unread 19-02-2009, 15:16
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
Re: Update #12
Originally Posted by wt200999 View Post
Does this also mean no wifi scouting?
Our team has the same question. (See also Update #13.) How are you guys planning to scout without wifi?
Unread 19-02-2009, 15:20
Re: Update #12
I expect we'll do it the same way we always do: clipboard, paper, and pencil.
Unread 19-02-2009, 15:22
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: Update #12
Originally Posted by Update 13
Wireless communication clarification:
Regarding the wireless communication prohibition in Team Update 12, we’d like to clarify that general cell phone use is permitted. However, Wi-Fi use in the 2.4GHz or 5GHz bands is prohibited.
Wetzel
Viva Olancho!
Update 11 EricH General Forum 27 23-02-2008 17:31
Update #19 GBIT General Forum 24 30-03-2007 09:15
Update #8 Nita General Forum 0 10-02-2006 23:51
Update 6 archiver 2001 1 24-06-2002 00:24
