Go to Post Is it weird that I was hoping we wouldn't have too many snow days so that graduation wouldn't run into Battlecry? - ScoutingNerd175 [more]
Unread 19-02-2009, 16:26
furiousgeorge's Avatar
furiousgeorge furiousgeorge is offline
FRC #3055
furiousgeorge will become famous soon enoughfuriousgeorge will become famous soon enough
Re: Axis Camera Help!!!
Originally Posted by Greg McKaskle View Post
my computer couldn't connect to this
Unread 19-02-2009, 17:32
I'm not sure what to tell you. It works fine for me. What happens when you try to view that page? What browser, OS, computer, etc. are you using?
Unread 20-02-2009, 12:34
FRC #3055
i need to know how to run the example. i'm not sure how to do it...
Unread 20-02-2009, 16:01
First get to the URL that has been posted. If your browser doesn't work, use another computer or figure out why. If that doesn't work, get someone from another team to email it. Without the source, you will not be able to run the source.
Second, open the lvproj.
Third, set the IP address of the cRIO in the project using the properties dialog.
Fourth, open the main VI, something about tracking two colors.
Fifth, press the run arrow.
Sixth, mess with it to figure out what works, what doesn't, how to use this in your program. It is just an example and will need to be altered to integrate into your app.
Greg McKaskle
Help: "Setup Axis Camera" sloteera Programming 9 16-01-2010 00:59
Axis Camera Help dnrobotics11 C/C++ 1 26-01-2009 18:10
Connecting Axis Camera Sauce Programming 8 18-01-2009 20:08
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
Axis Camera Testing help koo_04 Programming 7 20-12-2008 13:55
