Go to Post The toughest regional is always the one you are competing in! - AcesPease [more]
Unread 19-02-2009, 10:59
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Re: Blown up electrical board
Originally Posted by Alan Anderson View Post
What post said that? I'd like to know which connector it was talking about.
Either way, the cRIO has reverse voltage protection up to +/- 35V, so it is hard to imagine damaging a cRIO by connecting up any of the power system voltages in any particular order.
Unread 19-02-2009, 15:46
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Originally Posted by RyanN View Post
A = W / V
So 20W at 24V = 20W/24V = 10W/12V = 5W/6V = .83A Max
So if you measure the current from the Power Distribution Board to the cRIO, it should not go past .83A. If it does, then it's the cRIO, if not, it's the PDB.
Actually, the wattage of the cRIO would stay the same at 20 watts and the current would INCREASE with a lower voltage, so if the main battery starts running really low and the converter isn't running as efficiently and not outputting 24 volts, perhaps 22volts or 20volts the current would increase proportionally. so the cRIO could possibly draw more than .83A.
-Mike
Unread 19-02-2009, 16:51
AKA: Chris Rake
no team (Athena)
Except the cRIO is no where near fully loaded, so actual consumption is less than the 20W listed. But yes, current will go up as voltage goes down, until shutdown at ~15V (or so) when current will drop, along with power to the processor, FPGA, and I/O.
Unread 19-02-2009, 17:12
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
-Mike
True, that's why I put in all the math.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
pic: Electrical Board team63 Extra Discussion 3 05-02-2009 15:33
Electrical board materials? gwilliam Electrical 15 28-01-2009 10:53
Metal Electrical Board aaeamdar Rules/Strategy 3 16-02-2008 20:49
Team 384's Electrical Board!!! sayso_411 Robot Showcase 11 14-02-2008 21:51
pic: 494 Electrical Board. want2modmygt Robot Showcase 2 12-02-2006 14:28
