Go to Post Realizing your DON'T want to be an engineer is every bit as important as realizing you do - Lil' Lavery [more]
Unread 19-02-2009, 17:35
Connor's Avatar
Connor Connor is offline
FTC #3768 (Crusading Cucumbers)
Connor is an unknown quantity at this point
Lightbulb [FTC]: Light Senser
My code is trying to use the light senser to follow the white lines during autonomous. I have seen other teams do this and i was wondering if someone could post some code for it.
Thanks
"Never is just reven spelled backwards."
Unread 22-02-2009, 20:49
dooey100 dooey100 is offline
FTC #3037
dooey100 is on a distinguished road
Thumbs up Re: [FTC]: Light Senser
here is some basic code that will drive until your sensor hits the line:
motor[drive_right] = 100;       //start driving the motors
motor[drive_left] = 100;
while (SensorRaw[lightSensor] < tapeColor);      //keep driving until you run over the tape, tapeColor is a variable determined by the lighting and color of the tape, we used 340.
motor[drive_right] = 0;       //stop
motor[drive_left] = 0;
following the line is a bit tougher, the general idea is to go straight unless the light sensor goes off the line, if it does, turn until it is on the line again. Good luck getting it working, and if you need another hint, just ask!
Unread 23-02-2009, 14:24
gdo's Avatar
gdo gdo is offline
Never too much duct-tape ;)
AKA: Patrick
FTC #0001 (Team Unlimited)
gdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to behold
Send a message via AIM to gdo Send a message via MSN to gdo
On important thing is make sure you declare tapecolor with
int tapecolor = ____;
As for following the line, i would highly recommend two sensors for line following, just so you get a good tracking.
FTC #1: http://unlimited.syraweb.org
Got any question for me; AIM, MSN or PM me
Crio network light does not light when camera plugged in Bongle Programming 16 16-01-2009 11:00
[FTC]: FTC]: FTC Champ Tournament - Ontario (Scoring Breakdown) Mr. Lim FIRST Tech Challenge 2 03-03-2008 11:54
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
Multiple Light Tracking with Distinct Light Boxes in EasyC hal Programming 1 19-02-2007 11:56
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
