Go to Post "Trying to teach a nerd to be sensitive to girls is like trying to teach a dog Jamacian, and expect it to talk back" - Hansen302 [more]
Unread 19-02-2009, 17:44
Larry Wayne Larry Wayne is offline
FRC #0456
Team Role: Student
Larry Wayne is an unknown quantity at this point
TEAM 456 ROBOT TEASER
Are we the only team going for the empty cell..??
Unread 19-02-2009, 17:46
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: TEAM 456 ROBOT TEASER
What are those black connectors?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 19-02-2009, 17:49
Meredith Novak's Avatar
Meredith Novak Meredith Novak is offline
no team (Arkansas FIRST)
Meredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond repute
It looks like the aluminum tube frame system we used this year. Very light, strong, and easy to take apart if you modify something (not that we would ever do that...)
Unread 19-02-2009, 17:51
FRC #1405
Is there a site or something I can read up on for this stuff?
Unread 19-02-2009, 17:55
Here http://www.eztube.com/ is the material we used. It isn't very fancy, but we are pleased with it.
Team 456 - sorry to hijack your thread for a frame discussion. Is that the material you used? What did you think of it?
Nice robot, by the way.
Unread 19-02-2009, 18:10
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is online now
FRC #0456 (Siege Robotics)
It is 80/20 QuickFrame with associated connectors. We have used it extensively since 2006. Just go to the 8020.net website and look at their QuickFrame lineup. The connectors come in all sorts, corners, Tees, etc. and in black or gray. The QuickFrame tubing is fairly light (~.25/ft) and annodized so it looks better than regular extruded box tubing. It has longitudinal ribbing inside that grips the connectors so you just cut it on a miter saw and hammer the plastic connector in with a rubber mallet. Otherwise it is basically pretty similar to thin wall (1/16") aluminum box tubing. The weight of the connectors can add up though. For extra strength we add rivets here and there on the connectors as needed. Works great!
I am surprised the 80/20 QuickFrame isn't more popular in FIRST than it is. It is half the weight of 1010 T-Slot so many teams are so fond of. The QuickFrame also interfaces/connects nicely with the 10 Series if you say wanted to use the 10 Series on your frame/chassis and the lighter box tubing on your upper structure. 80/20 gives all FIRST teams a huge discount on all their stuff so we can actually buy the QuickFrame tubing cheaper than we can buy regular thin walled 1" 6061 AL box tubing. You can always just use the tubing as you would regular box tubing without using the plastic connectors and just weld it up, bolt it, or whatever you want. We've done that too over the years.
We used up over 200 feet of the QuickFrame tubing this year alone between the prototypes, practice bot, and the bot as shipped.
Unread 20-02-2009, 18:49
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
Wow, that looks EXACTLY like the same concept I came up with on our robot for opening and closing a gate. It's awesome to see that other teams can keep it simple by transfering motion from one device. I have seen so many other teams that use a motor to lift/move a gate, and another to dump/shoot the balls. More things to break like that......
Either way, it's cool to see another team think like us.
Unread 21-02-2009, 10:27
FRC #0456
Team Role: Student
ye we decided to build it as simple as possible...and we had to save all our motors for something else...
Team 25 Robot Teaser Mike Schroeder Robot Showcase 12 22-02-2008 11:08
pic: Team 456 jfish456 Robot Showcase 4 23-02-2007 00:38
pic: Team 456 (2) jfish456 Robot Showcase 6 22-02-2007 11:18
pic: Team 456 TEAM456MS Extra Discussion 1 01-03-2006 22:39
pic: Team 306 robot teaser Kyle A Extra Discussion 6 08-02-2006 18:11
