Go to Post They had a well made scouting form on the bottom was a check box with nothing next to it, when asked what the box was for they said. "Oh thats the jerk box" Since then one of our team goals is "Stay out of the jerk box" - Gary Stearns [more]
Unread 19-02-2009, 17:56
MPG's Avatar
MPG MPG is offline
Tutu Man
AKA: Michael
FRC #1259 (Paradigm Shift)
Team Role: Electrical
MPG is an unknown quantity at this point
Automation Direct Push Button
I was wondering if you could wire the provided Automation Direct push button to the driver station digital I/O and if you can how would I go about wiring it?
Team Robot Names
2010 = Oswald
2009 = Black Magic
2008 = Barnaby Rover
2007 = Z
2006 = Dilbert
2005 = Oder
2004 = Gerry
Unread 19-02-2009, 19:14
Re: Automation Direct Push Button
Any SPST switch will work on a Driver Station Digital Input. Connect the switch between Ground and Signal. Also connect a 10k resistor between Signal and +5V. You'll read 1 when the switch is open, and 0 when the switch is closed.
Unread 19-02-2009, 22:56
MPG's Avatar
MPG MPG is offline
Tutu Man
AKA: Michael
Thank you
That should help me alot
Team Robot Names
2010 = Oswald
2009 = Black Magic
2007 = Z
2006 = Dilbert
2005 = Oder
2004 = Gerry
Programming Direct drive with Direct (car like steering) tuna.and.cheese Programming 2 18-01-2009 11:26
Push Button and Switch Suppliers for OI controls Goldberg204 Control System 8 11-01-2007 15:27
Push Button System Rob2713g Programming 5 08-08-2006 21:20
push-button switch on robot Conan Electrical 4 10-02-2006 22:03
Team Automation Nathan Pell Team Organization 12 31-07-2003 10:37
