Go to Post FIRST is not about a robot competition . . there just happens to be one at every FIRST event. - Stuart [more]
Unread 19-02-2009, 17:14
Jessie2001's Avatar
Jessie2001 Jessie2001 is offline
FRC #2001 (CPR- Cougar Pride Robotics)
Jessie2001 is an unknown quantity at this point
Tethered connection to the robot?
Since the wireless wont be available at the competition. What changes do I need to make?
I believe it is:
Ethernet Port 1: To cRIO Ethernet Port 1
Ethernet Port 2: Laptop (IP: 10.xx.yy.6/ Gateway: 10.xx.yy.4)
Can someone please confirm this?
Unread 19-02-2009, 17:41
Re: Tethered connection to the robot?
The Driver Station ethernet ports are functionally interchangeable (assuming neither has failed). The only change you should need to make is to set the wireless security on your WGA600N according to the instructions you will receive at the regional.
Unread 19-02-2009, 17:44
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Alan, I believe what the poster is asking is how to set up their system for tethered operation for testing at their event.
As Alan said the DS Ethernet ports are interchangeable, but you are correct that one port goes to your laptop and one goes to the cRIO's Ethernet Port 1.
Unread 19-02-2009, 19:07
As I said, the only change for a regional event should be to the WGA's configuration. Tethering will work exactly the same as it already does.
Unread 19-02-2009, 23:41
pitzoid's Avatar
pitzoid pitzoid is offline
AKA: BOB
no team (4FX Design)
pitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of light
This is correct, at the regional you'll be given a sheet that has instructions to enter your unique WPA code. Makes sure your system is configured in accordance with FIRST Configuration guide . FMS will verify that all WPA keys have been seen by end of Practice day, just like inspections need to be done.
Some of the issues we saw at Suffield included people with their own configurations in their bridges, people leaving their dongles screwed on .... tight (and no one had a screw driver) and robots coming out on the field with dead batteries.
DON"T BE THAT GUY!
Good Luck everyone!
BotBash BOB Pitzer
Harvest CROO Robotics and 4FX Design
Unread 20-02-2009, 00:06
Jessie2001's Avatar
Thanks guys, exactly what I was looking for.
THe connection between the InviEW software and robot Spartan2432 FRC Control System 0 04-01-2009 13:25
Video Connection on the Field Coach Norm Championship Event 6 14-04-2008 18:36
The Lego / Google Connection JohnBoucher General Forum 3 29-01-2008 20:09
If it is tethered, is it a projectile? longwaytofall Rules/Strategy 13 07-01-2003 23:26
The Connection Game Jeff Waegelin Chit-Chat 1 03-01-2003 00:57
