Go to Post As long as this is a competition teams will push the limits. Those that succeed are those who can push the envelope and still stay within the lines. - Steve W [more]
Unread 19-02-2009, 20:18
Re: LabVIEW annoyance. help( not a hater thread)
I wasn't able to look into this today, day jog kept getting in the way. I hope to gain some insight, and hopefully a solution tomorrow. I currently can't explain or justify the time it takes. I looked into the one issue with the analysis libs and the checkbox and can pretty much explain that one. I'll certainly post as soon as I understand it.
Greg McKaskle
Unread 19-02-2009, 22:36
I turned off the virus scanner on our nice new Vista machine, and build time for our full project dropped drastically to just over three minutes. Mystery solved, I guess.
I checked the old XP laptop with 10-15 minute builds, and it only has 256 MB of RAM. Might that explain the extreme slowness?
Unread 20-02-2009, 08:30
That is helpful in more ways than one. The virus checker is concerned anytime disk activity is taking place, so this also points in the direction of overly disk bound activity.
The LV build used to be so simple. LV VIs are already compiled and the .o is bound inside of them. The files were aggregated into a primitive zip called an LLB, that was attached as data to the end of a tiny EXE wrapper that knew how to load the LV runtime engine, and we were off to the races. If you wanted it smaller, the other parts of the VI were stripped of diagram and some panel info.
With libaries, lots of things changed while I wasn't looking, so let me investigate. I'd like it to take less than a minute. I don't see why the build should be slower than the download.
By the way, noticed in my other post that I had a typo
Hah, day job is what was getting in the way, I haven't jogged in years.
Greg McKaskle
Unread 20-02-2009, 09:10
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
but im guessing the code compiled in these .o and exe wrapper segments are for an x86 processor, not for the processor contained in the rio? is this why it takes so long?
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 20-02-2009, 09:16
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
no I would expect that these .o files are for the power PC( its a power PC right?), although I do reserve the right to be wrong. Im curious to see if any one still has update 1 or update 2 on their computers, see if the change in the libs too place during that time.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
LABVIEW CODES NOT SAVING!!!!!!! PLEASE HELP!!!!!!!!!!!! GrammarNazi Programming 3 06-02-2009 14:26
I'm trying not to hate labview but... sparrowkc NI LabVIEW 14 22-12-2008 22:41
Activation of LabView still not working apollorest National Instruments LabVIEW and Data Acquisition 4 22-11-2008 21:09
frc_camera not working but labview does Issues Programming 7 18-01-2006 19:23
Audioscrobbler.com -- Go sign up! -- This is not like the other thread. Ashley Christine Chit-Chat 56 26-10-2005 17:41
