Go to Post I've come to the conclusion that the only way Pat's awesomeness can be explained is.... Pat Fairbank is a cookie. - Jonathan Norris [more]
Unread 19-02-2009, 17:56
MPG's Avatar
MPG MPG is offline
Tutu Man
AKA: Michael
FRC #1259 (Paradigm Shift)
Team Role: Electrical
MPG is an unknown quantity at this point
Automation Direct Push Button
I was wondering if you could wire the provided Automation Direct push button to the driver station digital I/O and if you can how would I go about wiring it?
Team Robot Names
2010 = Oswald
2009 = Black Magic
2008 = Barnaby Rover
2007 = Z
2006 = Dilbert
2005 = Oder
2004 = Gerry
Unread 19-02-2009, 19:14
Re: Automation Direct Push Button
Any SPST switch will work on a Driver Station Digital Input. Connect the switch between Ground and Signal. Also connect a 10k resistor between Signal and +5V. You'll read 1 when the switch is open, and 0 when the switch is closed.
Unread 19-02-2009, 22:56
MPG's Avatar
MPG MPG is offline
Tutu Man
AKA: Michael
Thank you
That should help me alot
Team Robot Names
2010 = Oswald
2009 = Black Magic
2007 = Z
2006 = Dilbert
2005 = Oder
2004 = Gerry
Programming Direct drive with Direct (car like steering) tuna.and.cheese Programming 2 18-01-2009 11:26
Push Button and Switch Suppliers for OI controls Goldberg204 Control System 8 11-01-2007 15:27
Push Button System Rob2713g Programming 5 08-08-2006 21:20
push-button switch on robot Conan Electrical 4 10-02-2006 22:03
Team Automation Nathan Pell Team Organization 12 31-07-2003 10:37
