Go to Post Ancient doesn't necessarily mean bad, but ancient things do fall out of use, otherwise I'd be tapping this out in morse code or writing it in Latin. - Greg McKaskle [more]
Unread 19-02-2009, 23:25
JamJam263 JamJam263 is offline
FRC #0263
JamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of light
pic: How high can u jump?
Unread 19-02-2009, 23:26
silicon_ghoti's Avatar
silicon_ghoti silicon_ghoti is offline
AKA: I think I'm a freshman?
AKA: Luke
FRC #1425
silicon_ghoti will become famous soon enoughsilicon_ghoti will become famous soon enough
Re: pic: How high can u jump?
Let me guess... a sudden change in the direction of a HUGE flywheel. Or am I mistaking the bulge in the center of the robot for something else?
What? You guys still opperate in only 2 dimensions?
This is a BEAR, it saves you.
Ghoti is pronounced "fish," ain't that sumthin'?
Unread 19-02-2009, 23:43
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
A jumping robot? Won't do you much good with a trailer -- but still awesome!!!
Im guessing you are not using this for the competition by the way
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 20-02-2009, 10:26
powerkane's Avatar
powerkane powerkane is offline
AKA: Earl Colter
FRC #0858 (Delphi Demons)
powerkane is an unknown quantity at this point
Send a message via MSN to powerkane
its the first lowrider robot it had hydrolics
Unread 20-02-2009, 12:07
Wylie99998 Wylie99998 is offline
FRC #0871
Wylie99998 is an unknown quantity at this point
Sachem haha love ur bot iv seen the vids the gyro is workin well 4 ya i hope u guys win the inovation award
Unread 20-02-2009, 12:17
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
I'm curious to see more, specifically how it relates to this:
http://forums.usfirst.org/showthread.php?t=11225
-John
Unread 20-02-2009, 12:24
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
If used for turning it is in no way aiding in traction, it is aiding in manuevering, so I see no problem, but, of course, I am not a ref nor a member of the GDC...
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 20-02-2009, 13:31
FRC #0263
You would be right, but "HUGE" depends on your point of view. If you think a 12" diameter, ~20 lbs fly wheel driven 1:1 by a CIM, is huge then yah, it's huge. It is the robot we're using, we just removed the top half of it for testing the gyro out, which is why the battery is held on with a clamp. We didn't mean for it to jump we were just testing out its driving capabilities. http://www.youtube.com/watch?v=hJMuKH9WkZo if anyone is interested to where the still frame is from.
Favorite 2009 quotes:
"Do we really need all of the cRIO or can we cut it in half to save weight?"
Unread 20-02-2009, 15:46
Brandon Holley's Avatar
It would turn signifigantly better if you guys could somehow shorten up your wheel base a bit....the shorter you make it the better it will be...
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 20-02-2009, 16:21
tanmaker
Posts: n/a
A little late in the season for that change
Unread 20-02-2009, 16:22
Elgin Clock's Avatar
FRC #0237 (Black Magic)
-John
I hate seeing Q&A posts that kill an idea I had early on in the season.
So much for making my own bot based on that very question by the team for off-seasons & just to play around with.
Unread 20-02-2009, 17:58
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
-John
If <R06> rules this out, I'll eat my hat. The gyro is applying a moment to the robot, not a force. The net downward force of the robot has to stay the same, as long as all 4 wheels are on the ground. If the gyro actually causes the robot to pop a wheelie as seen in the video, then that could be an infraction. Maybe. There's arguably an increase in normal force when the CoM accelerates upwards, and when the robot ultimately falls down again.
The mechanism obviously isn't designed with this in mind, however, so you can't declare it illegal, per the GDC's recent ruling about mechanisms that have the potential to exceed the starting size of the robot. At worst, the refs would call a penalty whenever the robot popped a wheelie. At which point, you'd have to penalize every robot that ever popped a wheelie from running into a wall, another robot, etc., etc. Which is ludicrous, to my mind.
Granted, I'm not the GDC, and they've been making some pretty difficult to enforce rulings lately in the name of applying rules universally and with excessive consistency... So I'll be on the lookout for good hat recipes, just in case.
Unread 20-02-2009, 22:40
FRC #0263
If its <R06> they DQ us on I'll eat my entire outfit. The only rule that I'm worried about is:
<R01>: Energy used by FIRST Robotics Competition ROBOTS, (i.e., stored at the start of a
MATCH), shall come only from the following sources:
A. Electrical energy derived from the onboard 12V battery
B. Compressed air stored in the pneumatic system, stored at a maximum pressure of 120 PSI
in no more than four Clippard Instruments tanks. Extraneous lengths of pneumatic tubing
shall not be used to increase the storage capacity of the air storage system.
C. A change in the altitude of the ROBOT center of gravity.
D. Storage achieved by deformation of ROBOT parts. Teams must be very careful when
incorporating springs or other items to store energy on their ROBOT by means of part or
material deformation. A ROBOT may be rejected at inspection if, in the judgment of the
inspector, such items are unsafe.
Other then telling us its storing energy illegally or storing it unsafely, I think we're safe
Unread 20-02-2009, 22:50
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
<R01> should not be a problem at all with this robot as I understand it. There is no energy stored in the motionless gyro at the start of the match.
Unread 20-02-2009, 22:58
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
how much does that weigh??
pic: Aiming High, even before 2006 FIRST Aim High RoboMadi Extra Discussion 7 29-10-2012 12:23
pic: how can i soften rubber colin340 Extra Discussion 10 29-10-2007 21:24
Safety of the players in the players station. How high is too high? Elgin Clock Rules/Strategy 9 24-02-2005 16:02
pic: How Many SPAM Kids Can You Fit in a Shower? CD47-Bot Extra Discussion 25 26-04-2004 09:02
Just how high can you climb? FatNick Technical Discussion 13 11-12-2002 08:20
