Re: Batteries Carried Into Competitions
Come on guys and gals. The GDC has ruled that batteries (alone) don't count against the withholding allowance. If you shipped your batteries and cables in the crate you have to assemble them in the pit, and if you didn't you still have to assemble them in the pit. There isn't anything to complain about on this front. It is a good idea to go over all those connections anyway, there are a lot of loose battery connections at competitions.
In my opinion, a lot of these rules adjustments result from pressing the GDC to clarify, and then clarify some more, instead of just letting common sense guide the interpretation of the rules. I wouldn't accuse the GDC of lawyering. It would appear that teams force them into corners with the constant challenges, and many of the responses are guided by the need to avoid the next corner.
The only rub here is that the unplanned impact of the weight of the cables on the withholding allowance is unfortunate. If you are impacted by this, you can solve the problem with COTS battery cables, they are available from AndyMark. You can also have a team that is way under the allowance bring the battery cables in for you. We would certainly do it for you, and we are way under our allowance because we shipped our entire robot, battery set, and cables in the crate. No doubt someone will worry about the legality of teams helping each other in this manner, and will ask the GDC about it. More power to you...
The most amusing thing about all of this is the fact that batteries and cables don't count towards the weight of the robot!
Eugene
