joystick axis in labview
Hello, I want to know how is the axis in joystick, because i want programing one motor that jostick when I move up, the motor moves forward,I move down, the motor moves back
And, how is the axis in jostick? Thank you ![]() |
Re: joystick axis in labview
You want to use the Joystick Get or Get Axis. I think Axis 2 is the Y. It returns -1 to 1 range, -1 forward and 1 backwards.
Outside the loop do a joystick open and close on the left and right. Greg McKaskle |
Thank you |
The other axis, are nothing to worry about... |
Actually axis 1 (x) is right/left, axis 2 (y) is up/down and axis 3 is the throttle on the bottom front of the joystick. The other axis don't exist on this joystick but other joysticks can have them.
Is the correct program for move one motor with only Axis Y Thank you!!!! |
#8
| Axis 3 on joystick | camper365 | Programming | 3 | 13-02-2009 22:49 |
| labview:what is the joystick axis? | mcristina444 | NI LabVIEW | 4 | 08-02-2009 13:26 |
| pwm outputs vs. joystick y-axis | stephenthe1 | Programming | 4 | 01-12-2004 17:29 |
| Inverting Y axis on joystick | FormatteD_C | Programming | 7 | 24-02-2004 16:56 |
| switching joystick axis????? | team222badbrad | Technical Discussion | 9 | 16-01-2002 23:07 |
