Go to Post I don't actually have any hex shaft stock in my house (I live in an unusual household). - ollien [more]
Go Back   Chief Delphi > Technical > CAD
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Unread 11-02-2009, 17:26
paigetee paigetee is offline
FRC #1535
paigetee is an unknown quantity at this point
Inventor vs. ProEngineer
I was wondering how many people use Autodesk Inventor versus ProEngineer?
Unread 11-02-2009, 18:16
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Inventor vs. ProEngineer
Put a Poll on there and I think one of these have already been made aka the thread. But to answer it:
-1. Solidworks
-2. Inventor
-3. Learning Pro.E
R.C.
MadTown Robotics Team 1323
Unread 11-02-2009, 18:57
I personally prefer:
Inventor
Solidworks
PAD (Pencil-Aided Design)
Pro-E, which I once tried to learn. When I tried a second time, I was less successful. I might try again at some point.
Unread 20-02-2009, 13:42
busted240sx's Avatar
busted240sx busted240sx is offline
FRC #0148 (Robowranglers)
busted240sx is an unknown quantity at this point
I prefer proE for machining things because it has the CAM program built into the package, which is nice if your design tends to change alot. It's harder to learn though, I'm sure I can only use about 10% of its real capability.
Inventor is much easier to use though, especially for students. I first learned to CAD with Inventor and I'm glad I started there, I would have gotten frustrated if I started with ProE.
148 - Robowranglers Alumni & Mentor 2005 & 2011
1817 - RoboRaiders Mentor 2008-2010
Unread 20-02-2009, 14:18
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
As a 10+ year Pro/E user, I am biased towards Pro. I have played with Inventor a bit this year, and see some similarities, but many drawbacks. My company is a Pro/E company, so I don't have much choice, but if I did, I'd stay with Pro.
Former Mentor Team 1771
Former mentor Team 4509
Unread 20-02-2009, 19:00
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
Pro E is an unforgiving program while Inventor is quite the opposite. I have to learn Pro E for one of my design classes in college after using Inventor for almost three years and I want to punch the screen every time I use it. The only thing I have found so far that Pro E handles better than Inventor is the placement of datum/work planes. With that said Pro E will not work well unless you have a thorough understanding of setting up references within your drawings.
Inventor>Pro E
Unread 20-02-2009, 19:10
martin417's Avatar
AKA: Martin Wilson
Inventor>Pro E
Actually, what you are describing is an advantage, not a disadvantage. In Pro, you must reference everything you model to a reference. You cannot have vague things floating in space. This is a good thing, since you always know exactly where things are.
By the way, it is best to speak of "models" instead of "drawings". The draing is only a representation of the model.
Unread 20-02-2009, 19:18
AdamHeard's Avatar
Lead Mentor
I've got a decent amount of experience with all three (the most with inventor), and from the perspective of someone trying to design something with many parts, then manufacturing it, I would say I prefer SolidWorks the most.
It's just the easiest and most intuitive to use, it also has a totally subjective more modern feel. I believe it's interface for sketches is far superior.
As for Pro/E having CAM as an advantage, there are similar options for solidworks (no idea for inventor).
Unread 08-03-2009, 13:55
grim's Avatar
grim grim is offline
Inventor Guru
AKA: Todd
FRC #0549 (Devil Dawgs)
grim is on a distinguished road
Just to be clear, Inventor was designed by ex-ProE programmers who wished to create a program that was easier to use than Pro and still did what they want.
Inventor was also created to be flexible in design and NOT be limited to having to constrain absolutely everything to a reference or define every dimension on a sketch. That type of constraint can interfere with the design process when you don't know exactly what it is you wish to define or wish to create an adaptive design.
It is just two ways to approach CAD design. Think ProE as more structered, Inventor as less structured. They are both good packages.
"Does fuzzy logic create lint?"
Inventor 2008 file open in Inventor 7? VEN CAD 1 09-02-2008 17:57
Inventor 2008 // last thread EVER about chains in Inventor? Dan Zollman Inventor 10 10-07-2007 20:01
help with the inventor[robot part missing] (ajuda no inventor[parte do robo faltando] team 2244 Inventor 6 12-02-2007 06:16
ProEngineer Tutorial ida_noeman Inventor 0 20-01-2007 13:06
Inventor 7 different from Inventor 8? RudimentaryPeni Inventor 9 11-11-2004 16:48
