Go to Post I think the best driver team of the post season would be Mike Wade and Pete Baltzell- because they have been driving that NASA field all over the Northeast so all of us can play.Thanks guys!! - Wayne C. [more]
Unread 20-02-2009, 21:54
tomy tomy is online now
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: autonomous mode help please...
then how do i change that to drive a head at have speed for 20 seconds forward
Unread 20-02-2009, 22:31
Change the (4) to (1) - so you do this only once
Remove the second Tank Drive and second Delay & FEED
Change the (1) input into the first Delay & FEED to (20)
Unread 20-02-2009, 22:36
Originally Posted by tomy View Post
sorry for all the questions but on the motor control for my manipulator shouldn't i have a joystick close...?
Yes, you're right. It does need a joystick Close too.
okay i am just hopping that you guys are right and that this will drive just like when i had it before
The last programmer I showed this to didn't remember that the PWM order feeding the Open 4 Motor vi mattered. No promises, but if you have trouble just ask at your Regional for a LabVIEW programmer to take a look.
Unread 20-02-2009, 22:48
so then is this right
Unread 20-02-2009, 23:00
Looks good.
P.S.
Change Arcade Drive to Tank Drive in "TeleOp Reset" too.
Unread 20-02-2009, 23:11
how sure are u that it will work, all of it jusst like i had it before
Unread 20-02-2009, 23:20
You can tell it to go for that long, though I'm not sure you really want to. Twenty seconds is probably going to be long enough for it to run into the side of the field. But the real issue is the length of autonomous mode during a competition.
Unread 21-02-2009, 10:04
do you have any suggestions...?
Autonomous mode help Drake Hunter NI LabVIEW 3 12-02-2009 01:52
Help needed in autonomous programming for hybrid mode Team_STORM Programming 3 21-01-2008 19:11
Autonomous Mode HELP! jesusescobar Programming 4 12-02-2007 12:02
Help - Making the autonomous mode razer Programming 5 31-01-2007 16:25
Simulating autonomous mode - i need help!! :( itay_ms Programming 5 21-01-2007 11:28
