Go to Post Team 1114 does not design or build ROBOTS. They build AWESOME. - DonRotolo [more]
  #31   Spotlight this post!
Unread 19-02-2009, 23:18
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Dedicated Empty Cell Handler?
I finally thought of the empty-cell strategy about half way through build season, but it was too late to implement by then. The coolest way to do it in my mind would be to build a robot with two catapults on it constructed so that, when the robot is right up against the outpost wall, empty cells can be dropped on top and instantly fired into each of the airlocks across field. 4 super cells in 4 seconds, unless you get bumped/mess up.
It's a bold strategy that sure would look cool; I wonder how many teams will manage to do it (or even try?)
  #32   Spotlight this post!
Unread 19-02-2009, 23:27
JM987's Avatar
JM987 JM987 is offline
High Rollers
AKA: Josh Mauro
FRC #0987 (High Rollers)
Team Role: Driver
JM987 has a spectacular aura aboutJM987 has a spectacular aura aboutJM987 has a spectacular aura about
Send a message via Yahoo to JM987
Check Out Our Website!
HERE!
- 2009 Las Vegas Regional Winners (thanks to 1622 and 1013)
- 2009 Las Vegas Regional Chairman's Award Winner
- 2008 IRI Winners (thanks to 330, 67, and 68)
- 2008 Archimedes Division Finalists
- 2008 Las Vegas Regional Chairman's Award Winner
- 2008 Las Vegas Regional Winners (thanks to 39 and 1013)
- 2008 San Diego Regional Finalists
- 2007 FRC World Champions (Atlanta thanks to 190 and 177)
- 2007 Newton Division Winner
- 2006 Las Vegas Regional Winner
- 2005 Las Vegas Regional Winner
  #33   Spotlight this post!
Unread 20-02-2009, 00:09
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
We have one. No one on my team wanted to do it at first, but being the lead build mentor I pushed for it and refused to back down from this one little system. My reasoning was something along the lines of "bots on Einstein will have one!".
At first it was going to be a long trough on the side of the bot, which wound up being to volumous to implement. We then integrated it in with our shooter design, which is a suspended turret.
All we have to do is drive as fast as possible, ram into the outpost, get the empty cell on our shooter ramp, reverse the shooter to back it up, then rev up the shooter, open the gate, and shoot the empty cell into the air lock when we're within 10 feet of it. We'll need some practice to get a shot off like that, but I expect that we'll be good at it by the time our 2nd regional rolls around.
We're really glad that I can be stubborn sometimes
GitHub
  #34   Spotlight this post!
Unread 20-02-2009, 08:03
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
If I could keep track of the number of times we've used that logic to drive decisions...
Thank-you 294 & 67
www.bobcatrobotics.org
  #35   Spotlight this post!
Unread 20-02-2009, 17:20
Founder Founder is offline
AKA: Riley Found
Founder has much to be proud ofFounder has much to be proud ofFounder has much to be proud ofFounder has much to be proud ofFounder has much to be proud ofFounder has much to be proud ofFounder has much to be proud ofFounder has much to be proud ofFounder has much to be proud of
Team 1141 has a designated EC system. It is located at the front of the robot just below the front of our hopper. It is just below the same height as the hole on the outpost so all the human player has to do is just push it through the wall(without putting their hand through the wall of course) and the robot sucks it in using a spinning roller. The roller is a similar design to the system that releases the balls from our hopper. we originally were going to use the ground pick up to capture and dump the EC but we felt that we would be passing by too many free MR on the floor on our way to the airlock. once at the airlock we just reverse the roller and it shoots the EC out from about 2-4 feet away.
  #36   Spotlight this post!
Unread 20-02-2009, 22:28
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Originally Posted by XXShadowXX View Post
My team has built a pseudo empty cell handling system, it holds a said empty cell in the front of the robot, over the collection mechanism, and when we want to eject it, we need to drive the collection mechanism reverse, forward, then reverse and it shoots right out into the airlock. Now the last challenge, convince my team to attempt to collect the empty cell in autonomous. (legal?)
I've been trying to get my team to do that too. And I studied the rules carefully. It is legal, just be careful to make sure the tongs don't get stuck in the robot before it starts to drive again. However, no one listened to me. O and our empty cell holder is our pick up mechanism. They can be delivered in the side and by reversing we eject it to the air lock.
  #37   Spotlight this post!
Unread 20-02-2009, 22:30
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
1557 has one, its just a servo and some signboard
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
  #38   Spotlight this post!
Unread 21-02-2009, 01:22
What tongs? The outpost doesn't have any.
  #39   Spotlight this post!
Unread 21-02-2009, 07:08
merybar's Avatar
merybar merybar is offline
AKA: Matt
FRC #0894 (Chargers Robotics)
merybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of light
Send a message via AIM to merybar
Team 894 has a seperate rotary pneumatic mechanism dedicated solely for the purpose of retrieving empty cells.
Team 894 Chargers Robotics
  #40   Spotlight this post!
Unread 21-02-2009, 07:29
merybar's Avatar
AKA: Matt
  #41   Spotlight this post!
Unread 21-02-2009, 09:14
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
(or even try?)
I tried to get my kids to think about this design also. They felt the Risk/Reward was too great. Instead we settled for a EC device on 424 (the robot on the right)
  #42   Spotlight this post!
Unread 21-02-2009, 10:42
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
We Don't have a dedicated Empty Cell "mechanism", but we do have two ways of getting an Empty Cell. To pick up an empty cell from the floor we just drive up to it, spin our roller slowly and then it gets wedged between the roller and a piece of polycarb, To offload it we just reverse the roller and the Empty Cell is ejected about 5 feet.
Or, we drive up the the outpost shield and the HP can put an Empty Cell directly into our conveyor system.
-Dustin Benedict
empty cell question sepf13 General Forum 2 05-01-2009 20:11
pic: Green Machine Competition - 10 Cell Fuel Cell Stack Conor Ryan Extra Discussion 18 04-01-2007 08:09
Calling Incorrect Interrupt Handler Tom Bottiglieri Programming 7 14-02-2005 18:06
Big Ball Handler Joe P Technical Discussion 4 14-01-2004 12:58
What is an interrupt handler? Adam Y. Programming 7 14-08-2003 10:26
