Go to Post When you are at the regional no one cares if you are a rookie. You are a part of the family. - scitecteach [more]
Unread 21-02-2009, 13:43
Hadar's Avatar
Hadar Hadar is offline
FRC #2630 (Thunderbolts)
Hadar is an unknown quantity at this point
Is it allowed to use prior years supply?
Hi everybody!
My team and I have a question, and we were hoping that you could help us.
Is it allowed to use CIM motors that have been provided in prior years Kits, and is it allowed to use Banebot Gearbox that has been provided in the 2007 Kit?
THANK YOU =)
Unread 21-02-2009, 14:51
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Re: Is it allowed to use prior years supply?
You are allowed to use CIM motors from previous years. The banebots gearbox from the 2007 KOP however is not legal. Those were made specifically for the KOP and are no longer available as a COTS item. These gearboxes had a flaw in the carrier plate and are no longer manufactured. However, banebots does sell an improved model with identical mounting holes and output shaft that is legal here:
http://banebots.com/pc/Closeout/GP-56012
Mens et Manus
Unread 21-02-2009, 15:05
Hadar's Avatar
thank you =)
Unread 21-02-2009, 16:52
CraigHickman
Posts: n/a
Please cite your rules for this. (both the motor and the Gearbox)
Unread 21-02-2009, 17:01
Ice Berg's Avatar
Seth Berg
AKA: Seth Berg
From the Q&A:
Posted by GDC at 01/26/2009 10:59:23 am
The Banebots P56 gearboxes were custom-made products supplied for the 2007 Kit Of Parts.
As such, they are prohibited from use in the 2009 competition by Rule <R32-B>. However,
Banebots P56-HC gearboxes, which are improved versions of the model supplied in the 2007
Kit, are available COTS items and may be used.
Posted by GDC at 01/22/2009 06:25:10 pm
If the CIM motors scavenged from a previous-year ROBOT are of the identical part number,
identical configuration, unaltered, unmodified, and still in "out of the box" condition, then they
may be used as the 1 or 2 additional CIM motors permitted under Rule <R51>.
Mens et Manus
Are we allowed to use default code? Comatose Programming 1 11-02-2009 21:14
What cylinders are we allowed to use? Sqwigy Pneumatics 2 06-02-2008 16:57
Are we allowed to use last year's pneumatics on this years robot? Tri_Lam Pneumatics 2 13-02-2007 23:50
Use of tanks from prior years. Alex N. Pneumatics 6 13-01-2004 22:19
are we allowed to use?? majormusic2005 General Forum 2 24-01-2002 23:29
