Go to Post Every event that starts with "a little bit of fun" has the potential to end in disaster. Please think about all possible outcomes before you do anything stupid. - sanddrag [more]
Unread 22-02-2009, 11:38
VEI Dude's Avatar
VEI Dude VEI Dude is offline
Mentor 4024, 4013
AKA: Neil the Real Deal
FRC #4013 (Jokers & Clockwork Mania)
VEI Dude has a spectacular aura aboutVEI Dude has a spectacular aura about
Is this allowed? -- DSC directly on 9403
Trying to shave every bit of weight possible, and wondering if we can legally do this. The DB-37 cable by itself is 0.5 lbs!
See attached...
Unread 22-02-2009, 11:59
Re: Is this allowed? -- DSC directly on 9403
I have no idea if it is legal or not, but I certainly wouldn't recommend it. You can easily damage the d-sub connectors that way. An early DSC concept was similarly cantilevered, but it was quickly dismissed for many reasons.
Why don't you just use a ribbon cable instead of the provided one?
Unread 22-02-2009, 12:01
VEI Dude's Avatar
Mentor 4024, 4013
I was actually planning to support it with a strap of metal. The ribbon cable is a great idea though, so I will investigate that.
Cheers,
-Neil.
Unread 22-02-2009, 12:52
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
can anyone reccomend a place to get 37pin male to female ribbon cable?
thanks,
Samir
Unread 22-02-2009, 13:20
O-H
FRC #0048 (Delphi E.L.I.T.E.)
thanks,
Samir
6' Multicolor:
http://search.digikey.com/scripts/Dk...A7MFB-3706M-ND
6' Gray:
http://search.digikey.com/scripts/Dk...A7MFB-3706G-ND
These are not listed in stock because they have to assemble the cable for you, but it takes very little time for them to complete and ship, from past experience with 15-pin cables.
I'm sure you could also order the consituent components (see the product description details) on Digikey if you wanted to make a shorter custom cable.
Unread 22-02-2009, 13:24
AKA: Samir Shaikh
FRC #4329
just remember that the cRio is grounded to its casing, so any metal around it is probably not a good idea.
Unread 22-02-2009, 13:29
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
That Sigital Sidecar is currently overhanging Slot 1 where the required 9201 Analog Module with Analog Breakout and Battery Monitoring jumper must be installed per <R64>.
Unread 22-02-2009, 13:39
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
wow is this a joke? You want to shave weight from the cable?
I really really dont recommend doing what you posted in the picture... Maybe try getting a lighter cable if you are that concerned from the weight.
Unread 22-02-2009, 13:43
We saved 5 or 6 ounces by using a 37-pin ribbon cable. Not to mention the nicer-looking connection.
Unread 22-02-2009, 14:08
VEI Dude's Avatar
Mentor 4024, 4013
I missed that R64 -- we are not using that module or it's breakout. So we have to have it on there anyway??? Or does the rule imply that if we're using it, then it must be in that slot?
Either way, we could've shuffled the other modules so the digital sidecar clears.
I'm looking at the DB37 w/ribbon connector option now. Yes, every bit of weight savings helps, because we don't want to comprimise the design.
Cheers,
-Neil.
Unread 22-02-2009, 14:12
The orange box after <R64> makes it clear that it's required for every robot (and even explains why it's required).
Unread 22-02-2009, 14:15
VEI Dude's Avatar
Mentor 4024, 4013
Okay, I'll check the docs when I get back tonight. Thanks!
Unread 22-02-2009, 14:16
Yes, you must have the analog module in slot 1 with a 12-volt supply connected from a 20 amp breaker on the power distritution and the analog breakout's jumper set to read battery voltage.
No, you can not shuffle modules. They must be in the defined slots. Mandatory analog in slot 1 (with battery monitor jumper) and digital in slot 4 (with attached sidecar connected to Robot Signal Light). Optional analog in slot 2, digital in slot 6, and pneumatic in slot 8.
Unread 22-02-2009, 14:48
VEI Dude's Avatar
Mentor 4024, 4013
Okay thanks. I'm going to leave the connection changes to the controls sub-team folks. I'm just trying to re-do the mount layout and board today for weight savings.
Unread 22-02-2009, 15:39
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
the scale doesn't care where you lose the pounds, and the wiring of a robot certainly holds a lot of weight. We lost 6 pounds when we re-imagined our electrical board.
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
which servo (step motor) allowed for this year? mahmosh Motors 7 20-01-2009 20:43
Are we allowed to use last year's pneumatics on this years robot? Tri_Lam Pneumatics 2 13-02-2007 23:50
Is this pneumatic component allowed? fallen751 Pneumatics 6 22-01-2007 21:22
Only two batteries allowed this year? DKolberg Electrical 9 18-01-2006 23:19
does anyone know if this is allowed?? archiver 2001 2 23-06-2002 22:44
