Go to Post In theory, this should work... Oops. - Eldarion [more]
Unread 22-02-2009, 11:49
AmoryG AmoryG is offline
FRC #2423 (KwarQs)
AmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud ofAmoryG has much to be proud of
2423 The KwarQs Picture #2
Here's a picture that does our drivetrain and chassis justice:
By far the best part of our robot. It's a crab drive, very fast (for this competition I think) and maneuverable, and very heavy. What do you guys think?
KwarQs 2423
2008 Boston Regional Rookie Allstars
http://whsrobot.blogspot.com/
Unread 22-02-2009, 12:02
s()n_of_@_g.U.n s()n_of_@_g.U.n is offline
FRC #1528
s()n_of_@_g.U.n is an unknown quantity at this point
Re: 2423 The KwarQs Picture #2
It looks pretty good. Plus, the extra weight should give you good traction on the Regolith floor. But I think you should put on some mesh or something to protect your parts from the ball. Also, it kinda looks like its a leaning a bit.
Unread 22-02-2009, 14:17
FRC #2423 (KwarQs)
Thanks. I think we were planning on covering up the top part of our bot (we took out the electronics before the ship date so we can do some further testing). Also, what do you mean by leaning?
KwarQs 2423
Unread 22-02-2009, 14:46
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
I contend that the weight difference will make no difference in traction acceleration.
EDIT: True, acceleration is different from traction. However, "good traction" implies an added benefit and, other than if one gets into a pushing match, traction is irrelevant since all the wheels are driven. That having been said, touche.
Oh, and sweet robot. I like the construction of the chassis (for what that's worth coming from a programmer).
I cut myself shaving with Occam's razor.
Unread 22-02-2009, 17:25
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Originally Posted by ComradeNikolai View Post
I contend that the weight difference will make no difference in traction.
This is not true. An increase in weight causes an increase in normal force, which directly leads to an increase in traction. Increased weight will not lead to increased acceleration however, as mass cancels in the equation for acceleration in a traction limited environment.
Basically, any robot with all wheels driven and no additional thrust mechanisms (props) should have the same maximum acceleration rate. The advantage to a heavier robot will be in a collision/pushing match.
Unread 22-02-2009, 18:27
The welding job on that frame is outstanding. Props to your welder. Very nice swerve.
Unread 22-02-2009, 18:53
FRC #2423 (KwarQs)
Thanks. Our welding was actually done mostly by I think a bicycle manufacturer called seven cycles. They did our welding last year to. We're very fortunate to have them.
KwarQs 2423
Unread 22-02-2009, 20:10
budly99 budly99 is offline
FRC #0314
budly99 can only hope to improve
Can you work on the electronics after shipping instead of shipping them?
Unread 22-02-2009, 20:11
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Yes, you have a 40 lb withholding allowance.
R.C.
MadTown Robotics Team 1323
Unread 22-02-2009, 20:13
Robot-pineapple's Avatar
Robot-pineapple Robot-pineapple is offline
FRC #2423 (Kwarqs)
Team Role: Electrical
Robot-pineapple is an unknown quantity at this point
We aren't really working on our electronics so much as testing programs on the cRIO, but yes, you don't have to ship your electronics.
A Picture of the Qulit Kmo General Forum 4 24-12-2007 13:34
Name the place in the picture feliks_rosenber Games/Trivia 4 07-12-2007 12:49
1511 Team Picture after the Hosting the Rochester FIRST Rally Mirza95vx Robot Showcase 1 24-02-2005 16:51
Guess the Picture.... plutonium83 Chit-Chat 7 22-02-2004 18:56
Who has the *best* picture of the competition at one of this years regionals? Alex Cormier Chit-Chat 11 30-03-2003 00:19
