Go to Post Yes, a big part of FIRST is learning from others. But a just as important part of FIRST is learning from discovery. - [more]
  #91   Spotlight this post!
Unread 22-02-2009, 14:11
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: pic/vid: Team 1114 - Simbot Panthro
Originally Posted by Josh Murphy View Post
What motor and gearbox did you use on your shooter?
What motor and gearbox did you use on your collector?
If you look closely they I believe they made custom gearboxes... Haven't got a close look at this bot yet.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
  #92   Spotlight this post!
Unread 22-02-2009, 16:24
MrFixIt2719 MrFixIt2719 is offline
AKA: Tarik Deland
FRC #1528 (Monroe Trojan Robotics)
MrFixIt2719 is a name known to allMrFixIt2719 is a name known to allMrFixIt2719 is a name known to allMrFixIt2719 is a name known to allMrFixIt2719 is a name known to allMrFixIt2719 is a name known to all
that is one mean looking bot
  #93   Spotlight this post!
Unread 22-02-2009, 19:10
Kush Kush is offline
AKA: Ian Koscielski
FRC #0772 (Sabre Bytes)
Kush is an unknown quantity at this point
sick robot, my team had thought of a similar design but decided to go in a different direction. looking forward to seeing you guys in GTR.
77 WHO??? 772!!!!!!!!
www.sabrerobotics.com
2008 Connecticut Motorola Quality Award
2008 Connecticut UL Industrial Safety Award
2008 Greater Toronto KPC&B Entrepreneurship
2008 Waterloo KPC&B Entrepreneurship
2008 Waterloo UL Industrial Safety Award
  #94   Spotlight this post!
Unread 22-02-2009, 19:56
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
I will probably be the first to say that I am not scared...
Formidable? yes, Unbeatable? no.
I think this year will most likely show advantage to alliance teamwork and covering your teammates on the field.
This is a fantastic robot though; impressive in design, construction and general workmanship, I don't think we could ask for better competition at GTR. See you there.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
  #95   Spotlight this post!
Unread 22-02-2009, 20:04
AKA: Ian Koscielski
what kind of motor did you use for the wheel that shoots the balls???
  #96   Spotlight this post!
Unread 22-02-2009, 20:44
cziggy343's Avatar
cziggy343 cziggy343 is offline
cziggy343
AKA: Chris Z
FRC #0343 (Metal-in-Motion)
cziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond repute
Send a message via AIM to cziggy343
[quote=,4lex S.;826547]
QUOTE]
thats what i was thinking... i just didn't want to sound like a raving lunatic... thanks for making me feel like im not alone
Diamond Bullet Studios Co-Founder
http://www.dbsgames.net/index.php
  #97   Spotlight this post!
Unread 22-02-2009, 20:45
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
I couldn't tell you either but your best visual clue is around 1:37 in the video. I am somewhat curious as well.
Great looking robot as always and Good Luck this season!
  #98   Spotlight this post!
Unread 22-02-2009, 21:10
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Nice looking machine once again 1114. I have a few questions if you don't mind.
Do you guys shoot at one speed or does it vary depending on the distance?
Is the deflector/backboard on your shooter shooting the balls up, down, or parallel with the robot?
We used two RS-545's on our shooter, and two Fisher-Price motors on our intake. Both sets of motors were powered through custom transmissions using gears from the KOP FP Gearbox. Our launcher is currently using a fixed speed. The hood for the launcher can have it's angle varied, such that it's shooting at any of the trajectories you described.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
  #99   Spotlight this post!
Unread 23-02-2009, 09:31
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Originally Posted by s_forbes View Post
I knew it! Pause the Robowranglers video (http://www.youtube.com/watch?v=aCVLZFyEI1Y) at 0:39, and you can see a picture of the Simbotics bot hanging on the whiteboard! Huzzah!
Good eyes, but you missed something at 0:32.
  #100   Spotlight this post!
Unread 23-02-2009, 10:09
The Solidworks shirt? Or the yellow shirt on the right in the second picture at that time?
Or the red shirt on the right just before 0:32?
Or maybe the prototype chassis?
  #101   Spotlight this post!
Unread 23-02-2009, 10:34
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is online now
AKA: Sean
FRC #2415 (Wired Cats)
It's 1114's entire superstructure sheetmetal all powdercoated.
Mentor 2415
  #102   Spotlight this post!
Unread 23-02-2009, 13:28
Sarah H's Avatar
Sarah H Sarah H is offline
klr b33s
FRC #0033 (Killer Bees)
Team Role: Driver
Sarah H is a jewel in the roughSarah H is a jewel in the roughSarah H is a jewel in the roughSarah H is a jewel in the rough
Originally Posted by KF987 View Post
I think shooters w/ turrets will be more effective in later rounds because all the robots will be moving the entire match and having a turret will help a lot. During qualifications dumpers may score more because teams are moving less & no shows ect...and if you have a dumper and you need to be lined up right on target it may be to late in the match to catch up when you get the opportunity to dump your load.
Keaton
I totally agree with you keaton. as long as you have a dud bot the dumpers will kick some butt. they will do teal well in qualifying. once people get comfy with deiving, they will try to keep out of the dumpers way. I also think people may be underestimating how easily you can get pinned
Kill Kill Killer Bees
  #103   Spotlight this post!
Unread 23-02-2009, 13:37
artdutra04's Avatar
VEX Robotics Engineer
^ Is failing at deleting a post today...
Art Dutra IV
世上无难事,只怕有心人.
Last edited by artdutra04 : 23-02-2009 at 13:41. Reason: sdcantrell56 posted first
  #104   Spotlight this post!
Unread 23-02-2009, 19:44
flyingcrayons's Avatar
flyingcrayons flyingcrayons is offline
Team 1089 Alum. RU Class of 2015.
FRC #1089 (Team Mercury)
flyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud offlyingcrayons has much to be proud of
sorry.... couldnt resist... awesome robot!!
  #105   Spotlight this post!
Unread 23-02-2009, 22:34
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
putting this type of robot on a team with a powerful dumper is probably the best strategy i can think of.
imagine this :
a powerful shooter like 1114 or 217 slams a robot up against the wall, t-bone-ing them. A power dumper like 148, 254, 968, etc. brings up the rear with a trailer load of balls to dump in. The pinned robot has almost no where to go and is at least severely impeded. the turret of the shooter can make up for the odd angle of collision, and makes up for their scoring power by giving the dumper a clean shot. the 3rd robot can assist in scoring, or at least provide defense to the scoring robots.
so, all you shooters, and all you dumpers, just hope you can get your alternate on your alliance, team picks this year are looking to be a lot more strategic than just stacking points up. somewhat like 2007 when the lifter was essential to the game breaking win.
i just managed to get this out now because i was watching how 1114 was attacking the trailers in the video, good work guys!
Pic/Vid The Original Team 20 bbr4d3r Robot Showcase 7 18-02-2009 23:05
pic: Team 1114 Drive team in the finals Dan 1038 Extra Discussion 30 24-03-2008 22:08
pic: Team 1114 - Simbot SS Karthik Extra Discussion 30 08-03-2008 13:21
pic: Team 1114 -- Simbot Prime Karthik Extra Discussion 62 31-07-2007 23:12
pic: Team 1114 Gearboxes CD47-Bot Robot Showcase 16 19-02-2004 12:16
