Go to Post do i even have to say anything about hurricane jeanne after my comments about charley, frances and ivan? :mad: but if i could, i would run all of them over with my robot... - Arefin Bari [more]
Unread 22-02-2009, 20:20
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Vex Sensors on FRC Bots?
http://www.vexrobotics.com/vex-sensors-products.shtml
I was wondering, has anyone used these sensors and how well do they work. Are they worth it?
Thanks everyone,
-rc
R.C.
MadTown Robotics Team 1323
Unread 22-02-2009, 20:27
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Re: Vex Sensors on FRC Bots?
Which sensors are you talking about?
The mechanical ones (Bump, limit switch, etc..) will probably wear out more quickly then higher quality ones. They are also way overpriced
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 22-02-2009, 20:28
R.C.'s Avatar
I was talking about all of them, which ever ones anyone has experience with. The pricing is fine for us because we have level one and two robotics class which gets extremely awesome discounts.
R.C.
Unread 22-02-2009, 21:03
Stvn's Avatar
Stvn Stvn is offline
FIRST Competition Competer
AKA: Steven Rhodes
FRC #0100 (WHS/CHS - WildHats)
Stvn is an unknown quantity at this point
Send a message via AIM to Stvn
We at Team 100 are using one of the line trackers to measure the speed of our shooter roller. We have the edge of our top roller painted half black and are using the sensor like an optical encoder. We've set up some LabView trickery to measure the time between the "pulses" of black and white and use that data to determine the rotational speed. There were a few programming kinks to be worked out, but the sensor worked as intended.
Early in the season, we tested a few other of these sensors (I believe it was only the limit switch and the ultrasonic sensor). We were able to successfully read their inputs on our cRIO test bed platform.
Unread 22-02-2009, 21:26
Boron + Z Boron + Z is offline
FRC #1675
Boron + Z will become famous soon enough
Team 1675 has used VEX quadrature encoders for the past two years; last year for our mecanum drive-base and this year for traction control. We've had a bit of trouble programming them (encoders) due to lack of experience with the new control system (we're using C++ and can't figure out why we're not getting period from our encoders). Othwerwise, the protective housing is a nice feature. I recommend their use.
Unread 22-02-2009, 21:27
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Vex sensors are nice for the most part. They're already wired for a PWM signal (the pins have to be changed to female though) which is really nice and they're fairly accurate for the most part.
The Encoders are pretty good from what I remeber, The line followers are really nice, the light sensors are kinda hit or miss, and the Ultrasonic Sensors are good to about 5 or 6 feet reliably.
As for the Limit Switches, they're good for small applications but I would make sure they're very well protected. The Bumper Switches are really nice though, I've never broken one and I'm not nice to my Vex stuff.
I've never used any of the never stuff like the Potentiometer or Accelerometer but they should be pretty nice.
-Dustin Benedict
Unread 22-02-2009, 21:34
The quality on VEX sensors is great actually...if used properly. The only ones I've have problems with are the bumper switches. Depending on the application they last as long as you want. We also get a discount because of our robotics classes, so the price thing isn't applicable to most teams.
I've tested limit switches on lifts before (frc) and they've worked well. The function was that when the lift hit the limit switch coming down it would trigger a shooter for the home made game we were playing.
Btw RC, you could've just continued in your original thread...
http://www.chiefdelphi.com/forums/sh...ad.php?t=69757
Unread 22-02-2009, 21:43
R.C.'s Avatar
I could've and should've.But didn't, i should've used the search toolbar feature. Dang the build season.
R.C.
Unread 22-02-2009, 21:49
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Team RUSH, frc27, is using the Vex Encoder for traction control.
We have also tested the potentiometer and IR sensor, but are not currently using them on our bot.
So far I'm very happy with their performance. The output of the encoder is not as clean as the Grayhill or US Digital versions we have used in the past, but they are reasonably priced, easy to get and very easy to interface with.
Highly recommended.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 22-02-2009, 23:38
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
In 2006 we used several of the Vex ultrasonic sensors and they seemed to work pretty well(even after getting fairly beaten up.)
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 23-02-2009, 07:18
Jared Russell's Avatar
Taking a year (mostly) off
We are using 3 Vex encoders on this year's robot (2 for traction control, 1 for our turret). No problems thus far (though we did accidentally wire one backwards on our twin, resulting in a $25 red plastic paperweight).
Unread 01-03-2009, 10:51
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
We were considering using the VEX ultrasonic this year. It was essentially hassle free to connect and program. Fairly accurate too!
Unread 01-03-2009, 13:12
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
We used the Vex ultrasonic last year to sense when we could pick up a ball, a micro switch for fork placement and the encoder attached to a Vex wheel for measuring distance for the autonomous section.
This year we are using the Vex pot as the sensor on where our shooter is postitioned. I have a quad encoder to test next week, it may become our position device.
I like the Vex senors since they come with mountings and are a little more forgivable to abuse. It's also a never ending source of amusement to me to have "little bot" components on the "big bot".
Unread 01-03-2009, 13:29
I'll sell you all the Vex quadrature encoders you could ever want for only $20 each!
Unfortunately, IFI will sell you the same part for $10 each: http://www.vexrobotics.com/vex-robot...oder-kit.shtml
Unread 04-12-2009, 21:16
Ripper Ripper is offline
AKA: Jack Cyran
FRC #2180 (Zero Gravity)
Ripper will become famous soon enoughRipper will become famous soon enough
In 2006 381 used a VEX ultrasonic sensor and it worked perfect. Those sensors are definitely a nice resource for FRC bots.
Vex Sensors for FRC R.C. Technical Discussion 2 27-10-2008 11:59
FRC #2669 KY Bots Website feliks_rosenber Website Design/Showcase 4 13-03-2008 07:49
paper: Applied Robot Programming for FRC 'bots garyk Extra Discussion 8 11-01-2007 16:56
All FRC sensors Morenoh149 Programming 1 12-05-2005 22:04
Can this Cheap LEGO RPM meter be used on FRC Bots?? Elgin Clock Technical Discussion 7 07-12-2004 15:28
