Go to Post Now, everyone knows that Oompaloompas are like bunnies in that they have an insatiable desire to multiply, and the same can be said with Michigan teams (with all due respect) which are currently multiplying and filling that hand-shaped democratic kingdom with their honorable number. - Eugenia Gabrielov [more]
Unread 18-02-2009, 23:04
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
WatchDog Timeout
Our auto code keeps auto disabling because the watchdog is timing out
We are using LabView and we are feeding it but for some reason it is still disabling auto mode after about 1-2 seconds
Can anyone post a pic or explain how they set up there watchdog?
Thanks!
Unread 19-02-2009, 10:39
Re: WatchDog Timeout
Use the default autonomous program as a guide.
It does, however, fail to feed the WatchDog immediately, so running it as is will get you the disabled blink right away.
The True/False input to the whole thing needs to be set to True for it to work.
You'll see the WatchDog is feed inside the loop that runs for 5 seconds, after which it leaves and stops feeding the WatchDog, so the blinky light will show up after 5 seconds.
Unread 20-02-2009, 13:27
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
try using highlight execution to watch what happens with the code. From there, you can make a decision as to where to put the watchdog so the auton doesn't time out.
The way I did it is like the example, but I made subVI's (as I used the same block of code over and over again) and forced a chain through device refrences. You can also try flat sequence structures if you don't want to go through the trouble of the subVI's
Unread 22-02-2009, 22:04
DhavalVashi's Avatar
DhavalVashi DhavalVashi is offline
FRC #1241 (Theory 6)
DhavalVashi is an unknown quantity at this point
if you have a lot of case structures, and you think ur code is taking too long to run within that particular case, then feed it in that case again (idk if thats allowed tho but it would probably work)
Watchdog darty NI LabVIEW 8 16-02-2009 09:11
error 5101 : Timeout Wynlyndd LabView and Data Acquisition 3 31-01-2006 14:05
Timeout!! Ricky Q. Rules/Strategy 19 01-04-2004 22:03
Microsoft Timeout AJ Quick Regional Competitions 12 09-03-2003 17:38
Timeout Ruling Discussion ram Off-Season Events 4 29-11-2001 13:38
