Go to Post It definitely looked like a penalty, but in FRC if it looks like a penalty and smells like a penalty, well, unfortunately it might not be. - Basel A [more]
Unread 23-02-2009, 11:02
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: Moving Camera Servos With Joystick Button
What Greg suggests will work great, just be careful about how often you change the angle. If you change the servo setpoint whenever the button is held down, then the servo will almost instantly go to it's extreme angle. The reason being that the loop runs really fast, so you increment the setpoint very fast and it builds up to the max quickly.
I would check the time and only do the servo code when a certain amount of time has passed.
Twitter Profile
Servos not moving Marlfox Electrical 2 09-02-2009 18:24
joystick button furiousgeorge Programming 5 07-02-2009 15:57
Programming a joystick button... programmr Programming 2 05-01-2009 16:13
using servos with camera team877 Programming 2 01-02-2007 21:26
Moving robot while tracking with camera questions... Steve Orr Programming 6 02-02-2006 22:24
