Go to Post ...thinking and learning never go out of style. - Rick TYler [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 23-02-2009, 12:37
Zflash's Avatar
Zflash Zflash is offline
AKA: Erich Zende
FRC #1319 (Flash)
Zflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud of
Re: 2009 Regional Webcasts
If anyone knows whether or not the Buckeye regional will be webcasted could you please announce it along with the link ASAP. We have some people here in SC that will not be able to make the trip but would like to watch the action if possible. Thanks
Peachtree '08 Champion Thanks 343 & 547
Galileo '07 Champion Thanks 173 & 1902
Palmetto '07 Champion Thanks 832 & 342
Boilermaker '06 Champion Thanks 1272 & 85
Unread 25-02-2009, 16:21
FRANK(WGH) FRANK(WGH) is offline
Webmaster - delphielite.com
AKA: Frank
FRC #0048 (Delphi E.L.I.T.E.)
Team Role: Webmaster
FRANK(WGH) will become famous soon enough
Send a message via AIM to FRANK(WGH)
The 2009 Buckeye Regional will be webcast by Delphi E.L.I.T.E. Team 48 with the help of Team 291, CIA. The link is http://live.delphielite.com.
I send a link to the Coordinator if the regional this morning and hope that it will be posted very shortly.
Frank Bosak
Collegiate Mentor Association
Team 48 - Delphi E.L.I.T.E.
Unread 25-02-2009, 18:37
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Help!
I'm at the BAE regional setting up... everything worked great at home... but (you knew there had to be a but)... at the arena everything works up to the ustream.tv broadcast window. It comes up after broadcast now, status says "broadcast stopped" and the green broadcast button isn't available. The server monitor window *IS* showing the video stream I'm sending... I suspect an arena network issue, but I've no idea if opening ports 1935 for both TCP/UDP in/out and the IRC chat port of 6667 will help. Its odd that the broadcast window shows the video... also the chat window is working. I'm stumped.
Any suggestions? The arena folks have left for the day so any changes will have to wait until tomorrow. Having a suggested shopping list of changes to try could help the process along.
Unread 25-02-2009, 18:55
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Originally Posted by dcbrown View Post
Help!
Sounds to me like connection issues, if you are seeing the video stream then it is all working on your end, but the video isn't getting out to the ustream.tv servers. Could be firewall issues or port issues (not sure about this), read through ustream.tv's help documentation and see what they say.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 25-02-2009, 19:07
Justin's Avatar
Justin Justin is offline
Never Forget FIRST 1992-2000
Justin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant future
Send a message via AIM to Justin
I'm not really sure why you would need to open inbound ports. I was under the impression that the whole idea of ustream.tv was to send video out to them so you didn't have to open ports and get into that mess. I would say make sure you are broadcasting against the right show. Also make sure that you have the video and audio source set right in the ustream console. In theory of course if you are seeing video on the server monitor then video is making it to ustream which would lead me to believe that it is something to do with the way the show is setup on the ustream side of things.
Sorry for not being able to be more specific but maybe something there will help. Good Luck.
Justin
Rookie Year: 1996 (Hexagon Havoc)
Robots: Hexcalibur (96), Blue Dragon (97), El-e-Vador (98), Astrobot 2000 (99), Last Chance (2000)
Unread 25-02-2009, 19:53
AKA: Bud
I setup a new channel for testing just in case - same issue.
I then dropped out of FME/push mode and used ustream's lower quality pull mode -- that works. But it means I can use the video switcher software because although FME recognizes it, ustream pull doesn't. Its on the menu, but selecting doesn't bring up any picture.
So, my guess is some type of incoming port issues since the vid stream appears in the ustream monitor window. It must not be able to verify the stream or some such and so refuses to broadcast it. Just my wag at this point.
Unread 25-02-2009, 20:21
Jno
Have you tried Stickam? Its basically the same thing as Ustream.tv
Not really sure what FME is, sounds like you are trying some switching software... have you tried without that? give us more details about your set-up so we can be of more help.
Unread 25-02-2009, 20:55
Ellery's Avatar Unsung FIRST Hero
Ellery Ellery is offline
Working on my 10 month old robot...
AKA: Ellery
no team (X-CATS - on Sabbatical)
Ellery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond repute
Send a message via AIM to Ellery Send a message via Yahoo to Ellery
The Finger Lakes Regional committee is still working this to see if they can do it this year. Last year it was broadcast Live over Time Warner cable TV on the education Access channel. The main issue I was told was they can probably get a line through RIT but that needs to go through a server externally to get the proper streaming bandwidth for a webcast. I'll let you know if anything comes up between now and next week. I used to post matches after we get it digitally recorded and clipped.
Xerox Sr. Systems Engineer
Other jobs: Retired X-CATS Team Leader, Inaugural FLR MC and plain ol' nice guy
Team# 191 X-CATS - Est.1992 (www.x-cats.org)
"We don't just build robots we build people..."
Unread 26-02-2009, 09:34
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Does anyone know if ustreamed regionals can be watched from the ustream app on the iPhone?
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 26-02-2009, 09:51
AKA: Bud
BAE Webcast - the FME push problem still exists. I'm connected to the arena server which has all ported enabled so I'm not sure what the problem is. I'll limp along in pull mode for now, but the quality will be less and I won't be able to do instant replays or switch to static camera view (which is what is currently playing).
Stumped at this point.
Unread 26-02-2009, 10:04
AKA: Bud
Its working. No idea what the real problem was, but I noticed in moving my PC it lost its mind as to time zone and thought it was PST. I changed it back to EST and I guess that allows ustream to validate the timestamp on the stream or something. (Note to self on this on for my standard checklist)
Yea ha. (doing my happy dance)
Unread 26-02-2009, 10:07
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
DCBrown great job I can see the field perfectly. However, there is this annoying buzzing noise coming in. Not sure what happened but it happened when the "live" appeared on the screen. presumably when you fixed your problem.
2008 Regional Webcasts Justin Montois Regional Competitions 2 20-02-2008 23:10
Regional Webcasts : Week 3 Nawaid Ladak General Forum 29 23-03-2006 08:39
2006 Regional Webcasts Sam J. Regional Competitions 45 13-03-2006 01:05
Regional Webcasts Archives? ChuckDickerson Regional Competitions 1 07-06-2005 23:16
Regional Webcasts Dr.Bot General Forum 57 14-04-2004 20:17
