Go to Post the best way to make things most unfair is to have different rules for different people. - Jack Jones [more]
Unread 13-10-2001, 14:08
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
broken jumper on controller
Yesterday an out of control driver (me) drove our practice base into the 2001 goals and broke the jumper that switches between the default/user program. I'm assuming other teams ran into similar issues, so what's the solution? Permanently selecting the user program is good enough for us. We need this fixed by Monday evening because we're using it in class to teach our students about the software on the robot. Thanks for any advice or help.
Mike
Unread 13-10-2001, 23:10
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Re: broken jumper on controller
Mike
What are you doing not covering up your electronics!!!
I think the jumpers on there are standard jumpers... the same size that are used in computers. You can likely buy them from any computer repair place or you can open up your system and yank one from the back your hard drive or cd rom (although I warn these devices may or may not continue to work). If the actual pins broke that the jumper connects to, you have a bigger problem... If that's the case I'd recommend (but really advise against) sauldering a small wire between the places the two jumpers used to be, but that might heat up some internal components to such an extent that you might permanantly damage the robot controller. I wonder if there is a default setting if you take off the jumper entirely?
Patrick
Unread 19-10-2001, 08:56
nwagers nwagers is offline
#0240 (Mach Vee)
nwagers is an unknown quantity at this point
Send a message via AIM to nwagers Send a message via Yahoo to nwagers
Being on team 111, don't you have previous controllers? I do believe that you can ship it to Innovation FIRST for repairs, but don't expect it by Monday.
Unread 19-10-2001, 12:02
Software guy
I know Pat, we need a lecture on covering our electronics. This is a practice bot that we slapped together quickly without bothering to but shields on (but we'll add them now). And yes, the pins broke, not the little jumper. Monday morning our electrical guy sauldered together the two pins that select the user code, and everything works fine. Another electrical guy on our team says he can replace the actual pins, so we'll look into that. The default setting when you completely remove the jumper is to do nothing
I think our team has 4 robot controllers, 3 on previous year's robots and 1 on our practice base. We didn't want to mess with the old bots to fix the practice bot.
Unread 22-10-2001, 08:18
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Funny that you say this. Just last Thursday, we ran into a similar problem. We were doing a demo at school conferences (shamelessly asking for money), and we ran into a problem. Our robot had been reprogrammed, and the new program was giving us trouble. We decided to switch back to the default, and when a teammember pulled the jumper, he lost it. We spent 20 minutes looking, and couldn't find it. How did we fix it? With a paperclip. All we did was bend a piece of the paperclip around the pins, and we were set. Office supplies may not be the best solution, but it works.
Unread 22-10-2001, 20:49
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Dan 550 is on a distinguished road
I believe that there was a spare jumper in the fine electronics bag this year, but don't hold me to that...
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
visibility of robot controller? davidzhang Rules/Strategy 5 26-01-2003 01:11
