Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. But crazy ideas tend to produce some excellent results. - Yipyapper [more]
Unread 20-02-2009, 14:38
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Measuring PWM input signals
Is there a way to read PWM input signals? We never got our FIRST provided accelerometer, and the one from last year works rather crappily... so we're experimenting with other ones. One I found has a PWM output signal, but I can't figure out what I should use to measure the signal appropriately. I have a feeling its in the counter object, but I'm not quite sure..
Thanks!
Unread 20-02-2009, 19:27
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Re: Measuring PWM input signals
You'll probably want to use an AnalogChannel of Accelerometer object. The counter is for monitoring digital inputs and when analog inputs cross a certain threshold. Since an accelerometer outputs an analog voltage relative to how much acceleration it's detecting, this wouldn't be that useful.
Also, make sure your electronics are competition legal--I know for a fact that last year's sensors are not, since they're custom parts.
Get yer robot source code here!
Unread 20-02-2009, 19:28
virtuald's Avatar
RobotPy Guy
Its not the FIRST accelerometer -- its output is a PWM signal, not an analog voltage.
Unread 23-02-2009, 12:57
virtuald's Avatar
RobotPy Guy
Useful information in this thread: http://forums.usfirst.org/showthread.php?t=12086
Unread 24-02-2009, 11:51
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
You could try adding a capacitor on the PWM signal line to act as a low-pass filter, and then run it into an analog input.
Or you could run the PWM signal into a digital input and use change notification (interrupt on logic level change). I did this to decode a PPM signal on a PIC micro and it works great.
Nathan
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 03-03-2009, 07:15
Analog's Avatar
Analog Analog is offline
AKA: Bob Most
FRC #2619 (The Charge)
Analog will become famous soon enoughAnalog will become famous soon enough
An RC lowpass filter may do the trick.
Debouncing signals king vash Programming 2 17-07-2008 11:07
change pwm range preserve input sensitivity Superstitions Programming 6 11-02-2006 20:59
PWM Signals stevex Programming 1 28-10-2004 18:03
IR signals inverted Atheist Electrical 10 08-02-2004 16:27
2.5 is alive !!!! (input ! .. more input ! ) Lloyd Burns Programming 2 14-01-2003 19:15
