Go to Post Ive always wondered about this - if DK has an alter ego, like Clark Kent and Superman - KenWittlief [more]
Unread 23-02-2009, 07:35
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
servo question
Does anyone know of a link to a good tutorial on how to program the hitec HS-322hd servos that came in the 2009 KOP?
I have a side project that I would like to use these on and could not find any useful infomration on Hitec's web site...
thanks
Unread 23-02-2009, 07:58
miniman's Avatar
miniman miniman is offline
FRC #0701
miniman is an unknown quantity at this point
Re: servo question
The 2009 WPI libary comes with a set of commands just for servos in labview and I believe there is a class for controlling servos in C/C++. We used the code for labview to control the servos on the robot with great success, for out "hooks of doom"
If you are looking for a way to control them with out the FRC code; the KOP servos take a signal voltage between 0 and 5 volts, the voltage represents the position of the servo, 0 being full in the first direction, 5 being full in the second direction. (Remember the jumper pin if using the digital sidecar. )
--The most exciting phrase to hear in science, the one that heralds new discoveries, is not 'Eureka!' (I found it!) but 'That's funny ...' -Issac Asimov
Unread 23-02-2009, 09:01
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: servo question
They do not work with an analog input(0-5 volts). They expect a digital pulse. PWM = Pulse Width Modulation. I believe 1.5 ms is neutral
The jumper pin on the sidecar provides a constant operating voltage to power the servo.
Unread 23-02-2009, 14:06
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Re: servo question
Check http://www.hitecrcd.com/servos/show?name=HS-322HD
Click the "View our servo manual" item. Opens a PDF with pulse voltage and timing specs.
Unread 23-02-2009, 14:31
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Re: servo question
RC servos are normally powered by nicad packs, nominally 7.2 Volts. Most don't work very well at 5V (unless they are 4.8V versions) which is why the sidecar powers them with a fixed 6V supply (the low point for a 6 cell pack).
The PWM signal is a 5Volt pulse. The pulse is nominally between 1.0 and 2.0 ms with 1.5ms representing the center position. The 1.0 and 2.0 ms pulse widths correspond to clockwise and counterclockwise travel limits.
The pulses are usually repeated at 30 - 100 hz. The off time is not critical as long as it is shorter than about 30ms.
If you intend to control your own servos or PWM devices you will get better results with an active buffer to drive the servo cable high and low through a series resistance . Look at the schematics for the sidecar to see how its done well.
Unread 23-02-2009, 14:37
Re: servo question
On re-reading your question: You are interested in a programming tutorial for the servos. What type controller aand what language?
Unread 23-02-2009, 15:10
Japper's Avatar
Re: servo question
Actually I am planning on using an Arduino to control the servos using it's C complier... I was just looking for information on the Hitec servos and didn't find anything useful on their web site...
Also, I was able to find some information on programming servos in general with the arduino on the arduino forum since posting this to Cheif Delphi...
thanks for the reply!
Servo Question pollyproof12 General Forum 11 11-11-2008 08:19
[FTC]: Servo Question roborat FIRST Tech Challenge 1 04-11-2008 18:29
HS-322D servo programming question JimHull Programming 12 10-02-2007 15:14
Question about CMUCAM servo output itsme Programming 9 13-01-2007 17:44
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
