Go to Post And I think the poll needs another option: WILL be under weight ... eventually ... just get me a drill. :D - Franchesca [more]
Unread 24-06-2002, 02:18
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
leaky pnuematics????
Posted by Tim Gates at 03/14/2001 6:50 PM EST
Engineer on team #288, RoboDawgs, from Grandville High School and X-Rite/Delphi.
When chasing around your fittings because you can not understand why your compressor keeps cycling on and off, plug your exhaust ports before you start tightning fittings. The cylinder piston seals are not perfect and some air can leak by from the pressure side to the exhaust side. These single solenoid valves connect the exhaust ports to one end of the cylinder all the time. If your exhaust ports are plugged and you can see a visible drop in your volume tank pressure, get out the check leak (or a spray bottle of soap and water) and start looking. Don't overlook the pressure relief valve that comes attached to the compressor.
[IMG] code is Off
pnuematics great_one411 Pneumatics 1 16-02-2003 11:50
Help with Pnuematics inwoodraider Pneumatics 3 30-01-2003 17:27
limits on pnuematics Ed Crammond Pneumatics 24 13-01-2003 12:17
Pnuematics Manual ark_1230 Pneumatics 2 09-09-2002 18:29
Pnuematics archiver 2001 4 23-06-2002 22:55
