Go to Post Ah, drills & motors. Brings back old memories of FIRST - nparikh [more]
Unread 22-02-2009, 20:02
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
FRC 2200 2009 CodeName: Dumpster
Hope to see everyone on the field.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 23-02-2009, 00:09
AdamHeard's Avatar
Lead Mentor
Re: FRC 2200 2009 CodeName: Dumpster
Real interesting.
Is that CIM assembly made so that part or all of it is housed inside the roller?
Unread 23-02-2009, 17:53
teampronto's Avatar
teampronto teampronto is offline
ʇsı1ɐıɔ&#4
AKA: Ka'i Kau
FRC #3070 (Team Pronto)
teampronto is an unknown quantity at this point
Send a message via AIM to teampronto Send a message via MSN to teampronto
Real interesting.
If it is, that is totally awesome
Unread 23-02-2009, 17:58
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Real interesting.
How would you get the wires to power if it's insides the roller?
Unread 23-02-2009, 18:34
AdamHeard's Avatar
Lead Mentor
I've seen similar setups for other rollers systems and for spinning drums on combat robots.
More often than not (for brushed motors) the motor is inside the drum, but doesn't spin with it and the roller sits on hollow dead axles or something that allows the wires to be run through.
I've also seen the motor spin with it and a slip ring is used.
Waaaaay off topic, but for outrunner brushless motors, most are two parts; a face that mounts that is usually about 1/4th the length of the motor or less (with the output shat), and the rear can that actually spins with the shaft. People have facemounted that guy, and pressed a tube onto the rear can to power the roller/drum.
Sorry for the threadjack, but please let us know what exactly that guy is for.
Unread 23-02-2009, 18:49
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Here's an example from our bot this year:
http://picasaweb.google.com/lh/photo...t=di rectlink
We have a hub inside our roller drum that is keyed, then we put the drum over the entire transmission. It eliminates any chain or gearing and looks a lot cleaner.
Mentor 2415
Unread 23-02-2009, 19:50
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
Are you worried about knowing how many balls are in your possession?
Queen's Applied Science '13, Applied Mathematics
Unread 24-02-2009, 06:59
Bochek's Avatar
AKA: Adam Bochek
Yes the CIM and gearbox fit inside the roller (which is a 4" piece of ABS Pipe)
The motor does not spin, the pipe spins around the motor, so no slip ring is needed.
And no, we are not worried about knowing how many balls we have in the bot.
pic: FRC 2200 MMRambotics 2009 Complete Bot Bochek Extra Discussion 5 04-03-2009 19:43
Trailer Frc 2009 frcchile Robot Showcase 1 23-01-2009 09:44
FRC Game in 2009 Weis Rumor Mill 49 02-01-2009 16:45
Dumpster Diving sanddrag Chit-Chat 38 12-10-2006 00:41
