Go to Post If you never reach out and experiment with different things, you will never have the courage to reach out again. It's only through experiments and experiences where we get to understand ourselves better. - Ken Leung [more]
Unread 22-02-2009, 17:42
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Re: Is this allowed? -- DSC directly on 9403
Switching to the 37 pin ribbon able will save weight, along with changing the material you are mounting your electronics to. 1/4" hardwood plywood works great and weighs next to nothing. It's less than lexan and very strong.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 22-02-2009, 21:14
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Originally Posted by Travis Hoffman View Post
One of my problems with ordering from places like Digi-Key is too many choices that I can't tell the difference between. For example, is the above cable any different/better than this one for $9 cheaper?
http://search.digikey.com/scripts/dk...C7MFG-3706G-ND
6' is a bit longer than we need. If we wanted to make our own to a custom length, can anyone recommend specific connectors and ribbon cable?
Thanks.
Unread 22-02-2009, 21:40
VEI Dude's Avatar
VEI Dude VEI Dude is offline
Mentor 4024, 4013
AKA: Neil the Real Deal
FRC #4013 (Jokers & Clockwork Mania)
VEI Dude has a spectacular aura aboutVEI Dude has a spectacular aura about
Well, it's done. We lost 10lbs 2oz with the mods, and only 2 unused cRio modules and 1 digital sidecar were dropped. We'll lose a bit more by changing that DB37 cable. I'll have our controls guys re-check it tomorrow for legality, etc.
Now if only *I* could lose 10 lbs in 8 hrs too...
Cheers,
-Neil.
Unread 22-02-2009, 21:58
VEI Dude's Avatar
Mentor 4024, 4013
It is on much thinner lexan than before, but with a thin strip of aluminum angle under it for support. It's very solid now. Wood would not have been a good option for my mods, because I used captive studs to mount the Jaguars under other components.
Wireless adapter not shown because that will be mounted elsewhere, but it was included in the final weighing. One spike was also included in the final weighing, but it will probably be deleted, as we will most probably eliminate the compressor and use 4 accumulators instead.
Cheers,
-Neil.
Unread 22-02-2009, 23:02
Kush Kush is offline
AKA: Ian Koscielski
FRC #0772 (Sabre Bytes)
Kush is an unknown quantity at this point
i don't know if this is allowed but i wouldn't recommend it. if there is a shift in the chassis from the violent ramming in this years game it could damage the pins which will be hard to fix.
77 WHO??? 772!!!!!!!!
www.sabrerobotics.com
2008 Connecticut Motorola Quality Award
2008 Connecticut UL Industrial Safety Award
2008 Greater Toronto KPC&B Entrepreneurship
2008 Waterloo KPC&B Entrepreneurship
2008 Waterloo UL Industrial Safety Award
Unread 23-02-2009, 15:42
j_johnson j_johnson is offline
FRC #0226 (Hammerheads)
j_johnson is an unknown quantity at this point
You will have to leave that spike on there, even if you are using accumulators. The rules require that the robot must be able to charge the accumulators with the compressor attached to the spike and the pressure sensor working as a cutoff, even if the compressor is off-board.
Unread 23-02-2009, 17:23
Please quote the rule that enforces this.
Unread 23-02-2009, 17:31
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
<R74> Compressed air for the pneumatic system on the ROBOT must be provided by the Thomas Industries compressor provided in the 2009 Kit Of Parts. Compressed air shall not come from any other source. The compressor may be mounted on the ROBOT, or it may be left off the ROBOT and used to pre-charge compressed air in the storage tanks prior to bringing the ROBOT onto the playing field. Off-board compressors must be controlled and powered by the ROBOT.
• Note: The only difference between an on- and off-board compressor is that the off-board compressor is physically removed from the ROBOT. The intent of this rule is to permit teams to take advantage of the weight savings associated with keeping the compressor offboard. However, using the compressor off-board of the ROBOT does NOT permit noncompliance with any other applicable rules.
Emphasis mine.
The offboard compressor must be run from the robot which means that the robot must have the electronics to properly run it installed which includes a Spike relay and properly installed pressure switch.
Unread 23-02-2009, 17:36
Originally Posted by Vikesrock View Post
Emphasis mine.
It does NOT say that the Spike and pressure switch must be on the robot. They may be with the compressor, on a compressor board. At least, that's the way I see it. (Note: if you do this, make sure that you make it easy to connect the Spike and pressure switch.)
Unread 23-02-2009, 17:40
Thanks Kevin. I had the same confusion that EricH states in the above post (Eric minds think alike?). Perhaps there is some Q&A that clarifies whether or not the spike can travel with the compressor.
Unread 23-02-2009, 17:45
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The Pressure Switch must be on the robot per <R73-C> and <R77>.
If you are planning on trying to ditch the Spike I would certainly submit it as a question to the Q&A. Based on the note accompanying <R74> stating that the only difference is the physical location of the compressor, I believe the Spike must be left on the robot at all times (however, my opinion doesn't really mean squat).
Unread 23-02-2009, 17:51
AdamHeard's Avatar
Lead Mentor
In 2006 the rules were written about the same, it seemed clear you needed the pressure switch, but the spike was unclear.
Through two regionals and champs, the inspectors made sure we had a spike on the robot, pressure switch on the robot and a manual release valve on both the robot and compressor side.
I'd say play it safe and put everything but the compressor and a manual release on the robot. The spike and sensor do weigh something, but just be happy you already saved the 5+ of the compressor.
Unread 23-02-2009, 17:52
Or must it? Pardon me, but <R77> specifies that it must be connected to the "high-pressure" side of the system, of which the compressor is a part. If the entire high-pressure side is on a compressor board, including the regulator (which is legal by <R75-D>), then the pressure switch must by rule <R77> be with the compressor.
It must also be connected to the DSC, and the cRIO must be programmed to handle it.
Unread 23-02-2009, 18:01
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Good point Eric, that brings up an interesting conflict with the rules as written.
If the regulator is kept off the robot per <R75-D> then the pressure switch must also be off the robot per <R77> however, <R73> requires that the pneumatic system on the ROBOT must contain a pressure switch.
Unread 23-02-2009, 18:22
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
There is one more thing in the picture that has not been mentioned. You have a label on your cRIO indicating that port #2 is on IP address 10.18.98.3. This is incorrect and will not work. Port #2 is hard coded to 192.168.0.3 and is used specifically for the Axis Camera.
The 10.xx.yy.3 address is not actually used in the systems as we are currently configuring them.
which servo (step motor) allowed for this year? mahmosh Motors 7 20-01-2009 20:43
Are we allowed to use last year's pneumatics on this years robot? Tri_Lam Pneumatics 2 13-02-2007 23:50
Is this pneumatic component allowed? fallen751 Pneumatics 6 22-01-2007 21:22
Only two batteries allowed this year? DKolberg Electrical 9 18-01-2006 23:19
does anyone know if this is allowed?? archiver 2001 2 23-06-2002 22:44
