Go to Post Continuous improvement isn't rocket science. - JVN [more]
Unread 23-02-2009, 17:18
ReaperGoat's Avatar
ReaperGoat ReaperGoat is offline
Volunteer
AKA: Ruth Toomey
FRC #0319
ReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud of
Send a message via AIM to ReaperGoat
Re: Rule G22
Were there any challenges?
Unfortunately, I couldn't tell if people were being allowed to challenge any of the calls, since we got there part way through. They had had an issue with the field earlier in the day, so they were running behind schedule. I'm guessing that there was at least one challenge, since one of the calls was overturned because one of the reset people moved a ball, but Andy Grady kept emphasizing that it was a penalty after every match. (I think a lot of the teams there were too worried about the robots working than making a challenge, with only 3 days left to fix anything that went wrong.)
Team 1735 Student (2006), Mentor (2008, 2009)
Team 190 mentor/mascot (2007, 2015, 2016)
Team 319 Mentor (2016-present)
FIRST Volunteer (2009-2016)
Unread 23-02-2009, 18:08
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Re: Rule G22
I said this last year, but it bears repeating: I don't care what whoever says at Kickoff, if it isn't in the rules, it isn't in the rules. If it isn't in the rules, it isn't a rule. If it's enforced as a rule, EVERY team that gets penalized has grounds for a challenge. And they've only got 1 update to make it a rule/not a rule.
You should be careful stating absolutes regarding the rules. There is usually room for various interpretations.
If there is no rules update that addresses this issue I would suggest asking the question at your driver's meeting. And in this specific case I suspect that it will not matter which SC is played, as long as there is a 1 for 1 relationship. However, please refer to the recent communication sent out by FIRST, which states in NO uncertain terms:
... once the Head Referee has made a decision, the decision is FINAL! FIRST will not overturn any Head Referee decisions...
So, challenge if you must, but I believe FIRSTs position is very clear on that point ...
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 23-02-2009, 18:35
Re: Rule G22
If there is no rules update that addresses this issue I would suggest asking the question at your driver's meeting. And in this specific case I suspect that it will not matter which SC is played, as long as there is a 1 for 1 relationship. However, please refer to the recent communication sent out by FIRST, which states in NO uncertain terms: So, challenge if you must, but I believe FIRSTs position is very clear on that point ...
In this case, the GDC has ruled in Q&A that penalties must be backed by the Manual. The refs at Suffield were apparently giving penalties that are nowhere to be found in the Manual. Until there's an Update that says that this is the procedure, or FIRST releases official documentation saying the same thing, this isn't a rule, or rather, not penalizable.
The "Challenge" I refer to is the clarification process, as teams may sometimes see it. I.E. Team YZXA goes to the Head Ref and says, "Excuse me, but why was this penalty given?" If a Head Ref can find a rule that says this, then the team has clarification. If a Head Ref can't find the rule, then he or she needs to retract the penalty if at all possible, similar to how a football ref can pick up thrown flags if he finds he made a mistake.
Unread 23-02-2009, 19:14
Mr_D_Mentor's Avatar
Mr_D_Mentor Mr_D_Mentor is offline
AKA: Frank D'Anna
FRC #5856 (The Bullbots)
Mr_D_Mentor is on a distinguished road
Re: Rule G22
I don't think anyone challenged, based on it not being a rule. We didn't bring a copy of the rules with us to the shakedown, and even if we did, I doubt we could have figured it out in time. It took me a couple of hours to convince myself when I finally looked it up the next day. I think everyone there just assumed that the officials must be right.
8th year mentor
Bullbots, First Team #5856
The Nuts & Bolts of Fury, FIRST Team #3525
Team MAX, FIRST Team #1071
Overdrive <G22> poll: yea or nay? Alan Anderson Rules/Strategy 55 12-03-2008 09:49
Rule G22 needs to be changed Dave Flowerday Rules/Strategy 122 10-03-2008 22:55
G22 Direction of Traffic Hilarity Kevin Sevcik Rules/Strategy 16 17-01-2008 22:30
problems with G22 JMH Electrical 2 19-01-2005 20:52
