Go to Post "We just fundraised $5000 for registration, and you spent it all on balloons?" - [more]
Unread 23-02-2009, 20:03
chenvoy chenvoy is offline
FRC #1689
chenvoy is an unknown quantity at this point
Re: Arcade Drive Issue and Pnuematics
Originally Posted by Alan Anderson View Post
Please read the 2009 FRC Game Manual, with special attention to <R77>. The cRIO code must use the Nason pressure switch in order to control the compressor.
Did you say that with my code the way it is that I should ,program wise, be able to set off the solenoid by my JoySticks Controller?
Non-Arcade Drive causes problems in Autonomous... pinballwizard96 NI LabVIEW 2 01-02-2009 20:45
Arcade/Tank Drive Malfunction piedmont Programming 2 19-01-2009 17:37
EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? mayazk Programming 2 16-02-2008 02:17
Arcade Drive Anfony VEX 4 08-11-2006 19:46
vex programming arcade drive setting Michael Leicht FIRST Tech Challenge 3 17-10-2005 21:26
