Go to Post Remember to ALWAYS use physics in engineering discussions. There is really no room for "feelings" in this sort of thing. - JVN [more]
  #31   Spotlight this post!
Unread 06-02-2009, 02:16
spazdemon548's Avatar
spazdemon548 spazdemon548 is offline
FRC #0548
spazdemon548 has a spectacular aura aboutspazdemon548 has a spectacular aura about
Re: Methods of adding ballast to underweight robots
If you are using pneumatics, you can put as many cylinders (not to be confused with accumulators) on as you want. If you hook them up to your 60 psi side, you will gain extra air storage while solving your weight issue.
  #32   Spotlight this post!
Unread 06-02-2009, 04:35
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
Might I suggest the Tumbleweed weight gain diet?
http://www.chiefdelphi.com/media/photos/31418
I would say its one of the fastest ways to add a few pounds to your bot!
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
  #33   Spotlight this post!
Unread 06-02-2009, 08:42
Bcox Bcox is offline
FRC #2062
Bcox is an unknown quantity at this point
Cool Re: Methods of adding ballast to underweight robots
Armor would be sweet hehe
  #34   Spotlight this post!
Unread 06-02-2009, 10:51
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
you could add underglow, LEDs/Neon lights, to your robot.
Armor would be sweet. Or you could take 30 lbs worth of tools and strap them to the robot. Then you'd never have to go back to the pit!
  #35   Spotlight this post!
Unread 06-02-2009, 11:12
Please don't do this. While I don't see anything in the rules to make it explicitly illegal, I consider it closer to the bad side of the "cheating" vs. "clever engineering" scale. The rules do say not to use extra tubing for this purpose, and I'd use that as an indication of the intent of the rules.
  #36   Spotlight this post!
Unread 06-02-2009, 12:04
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Throw in some diamond plate and make the delorean =]
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
  #37   Spotlight this post!
Unread 23-02-2009, 20:32
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
I'd like to start this discussion up again. We are underweight but also have skewed weights over each wheel. I've been thinking of riveting 2 foot long pieces of 1x1 (sealed on one side and removable cap on the other) to each corner "tier" (vertical beam on the bot that essentially form a box) and filling them with steel or lead shot. This way, we can quickly add more or less shot to each beam on thursday to adjust weight with each wheel resting on a cheapo bathroom scale.
Any thoughts?
thanks, Vivek
EDIT: What sort of store would have lead or steel shot locally? I know Mcmaster has it but shipping will be ridiculous.
"we don't build robots, we build people"
  #38   Spotlight this post!
Unread 23-02-2009, 20:43
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
dimond-plate is obviously the best choice
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
  #39   Spotlight this post!
Unread 24-02-2009, 00:23
Bob Steele's Avatar
AKA: Bob Steele
Try a local gun store. They should have lead shot in sacks for use by shotshell reloaders. They will have several different sizes...your choice.
Not cheap but you won't have to ship it..
  #40   Spotlight this post!
Unread 24-02-2009, 00:37
vivek16's Avatar
AKA: vivek
To err on the safe side, I should have some ideas on alternatives to lead shot.
I just got the idea to use pennies instead. They are cheap and easier to use.
With 2.5 grams per penny, 20 pounds of pennies costs about 36 dollars which isn't too bad.
-Vivek
  #41   Spotlight this post!
Unread 24-02-2009, 00:59
Bob Steele's Avatar
AKA: Bob Steele
I think you could use pennies ... They are just about 25% less dense than lead so that's not bad. Better than steel which is something like 30% less than steel
Steel bolts are cheap though...put them or pennies in a PVC pipe...
tungsten is what you really want... but expensive...twice as dense as copper..
pretty cool stuff...
R
  #42   Spotlight this post!
Unread 24-02-2009, 01:03
vivek16's Avatar
AKA: vivek
Turns out newer (past mid 1980's) pennies are actually 97.5 percent zinc and only have a 2.5 percent copper coating. Who knew?
I think either the pennies or just scrap bolts we have lying around will work. I'll have to take a look at our junk bins later this week.
-vivek
  #43   Spotlight this post!
Unread 24-02-2009, 01:14
natalie604's Avatar
natalie604 natalie604 is offline
President
FRC #0604 (Quixilver)
natalie604 has a spectacular aura aboutnatalie604 has a spectacular aura about
Send a message via AIM to natalie604
our team used rebar in 2007
it worked great for our purposes
  #44   Spotlight this post!
Unread 24-02-2009, 07:44
I think it is important at this point to remind everyone, that adding weight needs to be done in a manner that will not cause damage to the field or other robots. For that reason simply using tywraps to hold practice weights or lead blocks in place is not recommended. Use something much more reliable like a threaded fastener. Lead, if used, should be sealed or painted to minimize contamination and as Russ pointed out earlier, should not be machined in the pits.
From the pneumatics even if you don't use the system, the compressor and air tanks as well as actuators can be used as ballast using their normal mounting hardware.
R71> In addition to the items included in the Kit Of Parts, pneumatic system items specifically permitted on 2009 FRC ROBOTS include the following items. All included items must be“off the shelf” pneumatic devices rated by their manufacturers for pressure of at least 125psi, and used in their original, unaltered condition (except as required for assembly with other
components).
A. One or two additional Clippard air storage tanks (Clippard Part Number AVT-32-16), equivalent to those provided in the kit. This means that up to four, and no more, Clippard air storage tanks can be used on the ROBOT.
Lengths of heavy gauge wire can also be used and easily secured with wire ties. #4 or even #0 can be a way to distribute weight easily while increasing the robot weight.
I once had a team mount up a bench vise and another team mounted a toolbox to compensate for the loss of an arm or ramp that they decided was causing more harm than good. Both used heavy, threaded fasteners and of course fell under the COTS parts and cost basis sections of Robot Rules.
  #45   Spotlight this post!
Unread 24-02-2009, 10:50
Electrical Engineer
Rookie Year: 1995
... What sort of store would have lead or steel shot locally? I know Mcmaster has it but shipping will be ridiculous.
Any sporting goods store (and most Walmarts) sell steel BB shots for air rifles. That being said, I'd use pennies as noted by others...
If you go the "shot" route, please be sure that the "removable cap" you use is very secure. In the event that your robot tips over, pounds of "shot" spilling onto the floor will cause a very dangerous situation for referees, field reset, et cetera and will almost certainly get you disqualified...
Regards,
Mike
Mike Betts
As easy as 355/113...
Ballast Confusion Paul11 Technical Discussion 12 02-02-2009 15:12
Ok serious question ringo115 NI LabVIEW 2 24-01-2009 12:58
Ballast considered extra parts? Gabe Rules/Strategy 9 12-02-2007 10:47
Extra Discussion for Picture Discussion Ianworld Robot Showcase 1 31-01-2005 01:28
Serious OI problems Arrowsmith Control System 8 10-03-2004 14:36
