Go to Post Also, If I am not mistaken, the name indicates that your robot is female :P They're all female... like cars, ships, and airplanes. - JVN [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 23-02-2009, 22:46
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
CIM Hub
I found a CIM hub on Andymark.biz but it's out of stock
http://andymark.biz/am-0320.html
Any suggestions of a place I can get something similar?
The application for this Hub is to direct drive a roller (3" ID PVC tube) using a CIM
Thank you
Unread 23-02-2009, 22:53
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Re: CIM Hub
Hey,
I'm from team 694, I worked with you guys a bit at the NY regional last year on some motor issues. If you have something drawn up or have an idea of something that you want machined, PM and we could machine it down at our lab.
-Seth
Mens et Manus
Unread 23-02-2009, 23:00
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: CIM Hub
You could easily buy a 250 hub from AM and drill it to 8mm and broach a key way in it. That's what we did the week before AM came out with the new hub.
Unread 23-02-2009, 23:05
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: CIM Hub
Our intake is a belt driven CIM drive (16 tooth drive gear and 56 driven gear). We didn't use a keyway but just put a set screw in the keyway slot and another set screw 90 degrees away on the shaft. It seems to work ok. You definitely don't want to do this for higher torques but it's not horrible for a low torque application.
-Vivek
p.s. My point is that you don't need to use a keyway as long as you're careful.
"we don't build robots, we build people"
Unread 24-02-2009, 09:46
Brandon Holley's Avatar
Re: CIM Hub
-Vivek
Of all the lessons I've learned in FIRST...the one I've learned the hardest is never trust a set screw...
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 24-02-2009, 11:54
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: CIM Hub
AndyMark now has more of the 8mm Key Hubs.
Sincerely,
Andy
Unread 24-02-2009, 12:47
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: CIM Hub
I'll only trust a set screw if I can dimple the shaft first.
___________________
- Tennyson, Ulysses
Unread 24-02-2009, 13:28
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: CIM Hub
QFT
our 2007 arm joint had a sprocket attached by a set screw on the motor output shaft... needless to say we had a lot of slipping that year.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 24-02-2009, 15:27
vivek16's Avatar
AKA: vivek
Re: CIM Hub
The set screw does fall into the keyway slot and has shaft collars on either side.
As long as we can keep it the screw tight, we should be ok. We don't have the machining capabilities to broach a hole in a timing belt pulley.
-Vivek
Unread 24-02-2009, 16:17
Bill Beatty Bill Beatty is offline
#0071 (Team Hammond)
Bill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond repute
Re: CIM Hub
You really don't need a machine shop to broach the 2mm keyway. A broach and 8mm collar is not very expensive. We gently rap the broach with a hammer to drive it through the bore. Using a hammer seems to work better than pressing the broach, particularly in steel.
Mr. Bill
Sprocket with hub or without? Vikesrock Technical Discussion 5 15-01-2008 01:14
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Hub for Wheel attachments Lavapicker Kit & Additional Hardware 5 09-01-2007 19:27
Re: Connecting hub sprockets to shafts archiver 2001 1 24-06-2002 00:20
Connecting hub sprockets to shafts archiver 2001 18 24-06-2002 00:04
